Dear all,
I’m writing here to contribute a new community module in GeoServer:
gs-gwc-mbtiles
I’m working on implementing a new TileLayer in GeoWebcache to publish MBTiles files.
Note it’s not a blob store: a new MBTilesLayer will be available to expose map tiles from those .mbtiles files.
The GeoServer counterpart (the incoming gs community module) will setup needed dependencies to add that support to the integrated GWC.
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
