Dear all,
I’m writing here to contribute a new community module in GeoServer:
gs-libdeflate
Deflate compression/decompression is used by TIFF plugins when specifying DEFLATE compression on write or reading a Deflate compressed image.
The current ImageI/O plugin uses the ZLIB based Deflater:
(and related Inflater counterpart)
ImageIO-EXT recently added support for libdeflate-java, with version 1.4.2 having an SPI based logic to use the higher priority deflate plugin available in the classpath, when working with TIFF Deflate.
Some preliminary tests showed performance improvements in both reading and writing operations when using that lib on TIFF Deflate encoding/decoding with respect to the default one.(e.g. 10%-20% on reading, 40%-60% on writing).
Therefore, I would like to contribute a plugin for GeoServer that allows to use this new lib when DEFLATE compression/decompression is involved.
Related JIRA: GEOS-10465
Related GeoServer code branch:
https://github.com/dromagnoli/geoserver/tree/GEOS-10465
Note that also PNG Java encoder is using the ZLIB based Deflater so there is space for improvements on that area too. (That would be another step)
Daniele Romagnoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Ing. Daniele Romagnoli
Senior Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
