We'd like to create a new community module: jdbcstore, which implements the resource store (normally the data directory) as a jdbc database with BLOBs in it.
Kind Regards
Niels
Kind Regards
Niels
BLOBs in it.
+1
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
+1 from me.
Q: Is it worth a new module or should it be merged in with JDBCConfig? (Like would you ever want one without the other?)
On 9 December 2015 at 08:39, Niels Charlier <niels@anonymised.com> wrote:
We’d like to create a new community module: jdbcstore, which implements
BLOBs in it.Kind Regards
Niels
Geoserver-devel mailing list
Jody Garnett
+1.
Niels------------------------------------------------------------------------------
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/>
New Zealand
I can imagine use cases where you'd want jdbcconfig, but not particularly need jdbcstore.
I understood jdbcconfig was made primarily for scaling, but jdbcstore is really only that useful with clustering.
Jdbcstore is theoretically possible without jdbcconfig (although you'd have to load the module, you can configure it as disabled) but that seems silly to me (the catalog would then be stored in the jdbcstore db instead of its own, which would not scale well).
On 09-12-15 18:03, Jody Garnett wrote:
+1 from me.
Jody GarnettOn 9 December 2015 at 08:39, Niels Charlier <niels@anonymised.com <mailto:niels@anonymised.com>> wrote:
implements
database with
<mailto:Geoserver-devel@lists.sourceforge.net>
