[Geoserver-devel] New community module: json-ld
Dear all,
I'm proposing the addition of a JSON-Ld community module on Geoserver.
The module would provide the possibility to output features in a json-ld format, while using a json-ld file as a template to perform a mapping over features stream (both simple and complex ones), using xpath as well as cql function. The new functionalities will be built on top of GeoServer implementation of OGC WFS 2.0 and OGC Features API (former OGC WFS 3.0).
Best regards,
Marco Volpini
+1
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Marco,
+1
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Marco,
+1 :slight_smile:
Simone Giannecchini
@simogeo
Founder/Director
Hi Marco
+1 from me.
Torben
On Tue, Nov 12, 2019 at 12:14 AM marco.volpini@anonymised.com <marco.volpini@anonymised.com> wrote:
Dear all,
Best regards,
Marco Volpini
Geoserver-devel mailing list
