[Geoserver-devel] new community module: mbtiles
Hi everyone,
I would like to add a community module for the mbtiles format in geoserver. We also recently just started an unsupported mbtiles module in geotools, which lies the the foundations of the format. The geoserver package provides the outputformats for geoserver (this is similar to the geopackage modules in geotools and geoserver).
At this moment, a wms getmap outputformat is supported:
https://github.com/geoserver/geoserver/pull/416
This will output any getmap requests to an mbtiles database, splitting it in tiles, basically using exactly the same algorithm as the one for geopackage.
Regards
Niels
On Mon, Dec 9, 2013 at 2:35 PM, Niels Charlier <niels@anonymised.com> wrote:
Hi everyone,
geopackage.
Hi Niels,
question, give that GetMap can occur in any CRS, size and bbox, how is the
mapping between the request and the tile
structure in the mbtiles setup?
Also, are there overviews in the generated mbtiles output?
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Andrea, mbtiles is always in wgs84 global mercator. The bounds in the request are interpreted according to the CRS specified in the request, but after that the requested CRS is ignored. The bounding box is used, but I think the size is ignored. Justin can probably answer your questions better than me, because he wrote the actual code for the mapping to tiles. I made it generic so it works for mbtiles as well as geopackage. Regards Niels
Hi everyone,
Hi Niels,
question, give that GetMap can occur in any CRS, size and bbox, how is the mapping between the request and the tile
Also, are there overviews in the generated mbtiles output?Technical Lead
Hi everyone,
geopackage.
Hi Niels,
Yeah, the mbtiles spec mandates spherical mercator, so any wms request
bounds will have to be reprojected to epsg:3857. To get around the mercator
pole issue from what I have seen typically the bottom and top 5 degrees are
clipped off.. so that may be a heuristic we want to apply to the case where
the user requests "the world" in geographic. Once the bbox is reprojected
it is aligned to the built in google mercator tile matrix provided by gwc
choosing a "best fit".
As for overviews the mbtiles structure has no explicit notion of them but
it is a multi level pyramid of tiles so as you go up zoom levels you get
more detailed tiles, so I guess you could look at that as an implicit
overview. Not sure if that answers the question.
Regards
Niels
*Justin Deoliveira*
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive <https://twitter.com/j_deolive&gt;
On Mon, Dec 9, 2013 at 5:42 PM, Justin Deoliveira <jdeolive@anonymised.com
I'm a bit weirded out about the CRS lockin, but I see it's indeed in the
spec. I guess it will have never any use for polar/high latitude mapping...
:-p
Good idea to cut the request area to the -85/85 latitude range (and
eventually throw a meaningful exception is the requested area is fully
outside it?)
Ah yes, I really meant, is just one zoom level returned, or do you generate
also the lower zoom levels for faster display in output?
Anyways, +1 on the module, I was just being curious.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Dec 9, 2013 at 9:47 AM, Andrea Aime <andrea.aime@anonymised.com>wrote:
:-p
outside it?)
Indeed. This is actually an area where i think geopackage can be useful if
it gets any traction since it doesn't have this limitation.
generate also the lower zoom levels for faster display in output?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
EPSG-registry says that 3857 is valid in World between 85.06°S and 85.06°N
http://www.epsg-registry.org/report.htm?type=selection&entity=urn:ogc:def:crs:EPSG::3857&reportDetail=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20Default%20With%20Code&title=EPSG:3857
MapProxy extents and breaks MBTiles spec and allows all gridsets, see thread http://lists.osgeo.org/pipermail/mapproxy/2013-November/001796.html
-Jukka Rahkonen-
Justin Deoliveira wrote:
On Mon, Dec 9, 2013 at 9:47 AM, Andrea Aime <andrea.aime@anonymised.com<mailto:andrea.aime@anonymised.com>> wrote:
On Mon, Dec 9, 2013 at 5:42 PM, Justin Deoliveira <jdeolive@anonymised.com<mailto:jdeolive@anonymised.com>> wrote:
Yeah, the mbtiles spec mandates spherical mercator, so any wms request bounds will have to be reprojected to epsg:3857. To get around the mercator pole issue from what I have seen typically the bottom and top 5 degrees are clipped off.. so that may be a heuristic we want to apply to the case where the user requests "the world" in geographic. Once the bbox is reprojected it is aligned to the built in google mercator tile matrix provided by gwc choosing a "best fit".
I'm a bit weirded out about the CRS lockin, but I see it's indeed in the spec. I guess it will have never any use for polar/high latitude mapping... :-p
Good idea to cut the request area to the -85/85 latitude range (and eventually throw a meaningful exception is the requested area is fully outside it?)
Indeed. This is actually an area where i think geopackage can be useful if it gets any traction since it doesn't have this limitation.
As for overviews the mbtiles structure has no explicit notion of them but it is a multi level pyramid of tiles so as you go up zoom levels you get more detailed tiles, so I guess you could look at that as an implicit overview. Not sure if that answers the question.
Ah yes, I really meant, is just one zoom level returned, or do you generate also the lower zoom levels for faster display in output?
Ing. Andrea Aime
@geowolf
Technical Lead
phone: +39 0584 962313<tel:%2B39%200584%20962313>
fax: +39 0584 1660272<tel:%2B39%200584%201660272>
mob: +39 339 8844549<tel:%2B39%20%C2%A0339%208844549>
Justin Deoliveira
@j_deolive<https://twitter.com/j_deolive&gt;
On Mon, Dec 9, 2013 at 6:08 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com>wrote:
I guess that's fine because MapProxy knows which SRS each sqlite file is in.
But in an output format, where would you register that info so that the
information is mantained after the file is registered on the client?
I guess some new tables would be needed?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
+1 on the module here!
more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
mob: +39 331 6233686
On Mon, Dec 9, 2013 at 6:16 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
On Mon, Dec 9, 2013 at 6:08 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com> wrote:
Sponsored by Intel(R) XDK
Develop, test and display web and hybrid apps with a single code base.
Download it for free now!
http://pubads.g.doubleclick.net/gampad/clk?id=111408631&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
I guess that’s fine because MapProxy knows which SRS each sqlite file is in.
But in an output format, where would you register that info so that the information is mantained after the file is registered on the client?
Ing. Andrea Aime
@geowolf
Technical Lead
On Mon, Dec 9, 2013 at 10:16 AM, Andrea Aime
thread
in.
There is actually already a metadata table in MBTiles that is just a set of
key/value pairings. So if we were to extend the spec i imagine stuff like
srs would go there. Regardless our plan is to stick with strictly what is
supported by the spec but if there is overwhelming feedback that additional
projections are wanted it should be fairly straight forward to accommodate.
information.
Ing. Andrea Aime
@geowolf
Technical Lead
*Justin Deoliveira*
There is actually already a metadata table in MBTiles that is just a set of key/value pairings. So if we were to extend the spec i imagine stuff like srs would go there. Regardless our plan is to stick with strictly what is supported by the spec but if there is overwhelming feedback that additional projections are wanted it should be fairly straight forward to accommodate.
Applications made by/for Finnish administration do not use spherical mercator tiles so we do not have much use for MBTiles. However, storing and delivering tiles in some kind of file database feels interesting. What would you store as key/value pair for making the client to understand the tiling schema well enough? Could it be something like the whole <gridSet> of GeoWebCache config file as in http://geowebcache.org/docs/current/configuration/layers/projections.html or what?
Some other name than MBTiles (MapBox tiles?) would be needed for the derivative. Could it be DBTiles? Or GTTiles or GSTiles like in DataBase, GeoTools or GeoServer, respectively?
-Jukka Rahkonen-
On Mon, Dec 9, 2013 at 2:34 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com>wrote:
accommodate.
http://geowebcache.org/docs/current/configuration/layers/projections.htmlor what?
Well I believe this is what the tile portion of the GeoPackage spec
addresses. It has no restriction on projection and as you state it has a
metadata table that describes the tile matrix structure. So from our
perspective it seems like a pretty good fit for folks who need more than
spherical mercator.
-Jukka Rahkonen-
*Justin Deoliveira*
