[Geoserver-devel] New community module: OGC API 3D GeoVolumes
I want to add a very light implementation of OGC API, 3D Geovolumes, as a community module.
It’s going to be something unusual for GeoServer, as the 3D tiles are produced externally and provided as static files, so GeoServer really just needs to read a JSON collections.json file, that contains the collection structure, and basically serve it back with minimal massaging.
It’s going to be very similar to this javascript based implementation:
https://transfer.hft-stuttgart.de/gitlab/ogc/3dgeovolumesapi/-/tree/master/
which is basically driven by a user provided file, with some ability to ajust the URLs provided to consider proxy base URL, self links, and generate a HTML representation of it:
https://transfer.hft-stuttgart.de/gitlab/ogc/3dgeovolumesapi/-/blob/master/3DGeoVolumes/collections/collections.json
I’m going to note the odd setup in the documentation.
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
+1 community modules are a great way to explore concepts.
Jody Garnett
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
