On Fri, Sep 4, 2015 at 4:30 PM, Simone Giannecchini <
simone.giannecchini@anonymised.com> wrote:
Ciao Ian,
I am +0 here, I will let others chime in (Jody? Andrea?).
+1 on the module, it's a community module, out of the way, implementing an
existing extension point.
+0 on the improvement on the UI, I don't see particular issues, that part
of the GUI
is brand new anyways, we can double/triple check the changes to that one
class
are ok before porting back to the (new) stable series (aka 2.8.x, once it's
cut)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
