[Geoserver-devel] new community module workflow
Hello,
I would like to create a new community module in geoserver called "workflow".
The purpose of the module would be to create certain tasks and schedule them in batches that are automatically executed.
Examples of tasks are:
- update layer data from a source to local
- synchronise data and metadata with other geoservers
and this can easily be extended upon of course.
Please let me know if this is OK.
Kind Regards
Niels
No objections. This seems to have some overlap with importer own list of tasks, but it’s more general.
On Wed, May 24, 2017 at 1:08 PM, Niels Charlier <niels@anonymised.com.> wrote:
Hello,
“workflow”.
  • update layer data from a source to local
  • synchronise data and metadata with other geoservers
Kind Regards
Niels
Geoserver-devel mailing list
Geoserver-devel@anonymised.com.366…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
+1 for me, sounds interesting
Ian
On Wed, May 24, 2017 at 1:08 PM, Niels Charlier <niels@anonymised.com> wrote:
Hello,
“workflow”.
Kind Regards
Niels
Geoserver-devel@anonymised.comrge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Ian Turton
Looks nice, wich framework are you going to use? There’s some stuff in the backup and restore community module working with spring-batch. Maybe you can take a look at it and see if things can be somehow homogenized.
+1 anyway
Ian
Ian Turton
Hello,
“workflow”.
Kind Regards
Niels
Ing. Andrea Aime
@geowolf
Technical Lead
I am not against this and you already have enough +1, however it would
good to hear your thoughts on the following points:
- did you assess the overlap with existing extensions like the Importer?
- which framework do you intend to use?
There is a huge number of modules in GeoServer with overlaps and we
keep on adding new ones without harmonizing...
Simone Giannecchini
Visit http://goo.gl/it488V for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
Hello,
"workflow".
Kind Regards
Niels
Check out the vibrant tech community on one of the world's most
+1, sounds good.
Importer and the backup restore module also have some kind of tasks model. If I remember correcly the backup-restore module used a spring api that may be a useful starting point?
On 24 May 2017 at 04:08, Niels Charlier <niels@anonymised.com> wrote:
Hello,
“workflow”.
Kind Regards
Niels
Jody Garnett
Niels,
+1 for the concept.
Have you considered a different name? The term "workflow" is used for a variety of different purposes, including business workflows, and systems for orchestrating collections of services. For example, there are many scientific workflow management systems:
https://en.wikipedia.org/wiki/Galaxy_(computational_biology)
https://en.wikipedia.org/wiki/Apache_Taverna
https://en.wikipedia.org/wiki/Kepler_scientific_workflow_system
https://en.wikipedia.org/wiki/Scientific_workflow_system
What is the scope of your module? Does your module only schedule tasks or batches of tasks? Will it wait for task completion? Can tasks trigger other tasks? Are all the tasks local? Can tasks be invoked with parameters? Will the module manage or record task output?
A module name like "scheduled-task" might be suitable if that is the main functionality that it provides.
Also, how are tasks specified?
Kind regards,
Ben.
On 24/05/17 23:08, Niels Charlier wrote:
Hello,
"workflow".
Kind Regards
Niels
Ben Caradoc-Davies <ben@anonymised.com>
Director
Transient Software Limited <http://transient.nz/&gt;
New Zealand
Hello Simone, Alessio, and Jody
Thanks for your input.
I have assessed the overlap with other modules, and I don't think there is much, if any. But I am open to suggestions as always.
As I understand it, the main purpose of the Importer is publishing many layers at once. The workflow module will initially be focused on single-layer configurations. Its main purpose is to be able to manage a flow of data (and metadata) that runs over a series of servers, for example like this:
ORIGINAL DB / HARD DRIVE --> WORK-GEOSERVER --> PUBLIC GEOSERVER
and to execute this or part of this, manually or automatically if possible and desired.
In the future it could be interesting to connect the modules with each other, through the creation of importer tasks and backup/restore tasks that can be scheduled in the workflow module.
I don't think Spring batch is useful for me, because the idea is to allow users to specify tasks and batches in a GUI, and store them in DB, rather than hard-configuring the batches in the application context. Unless you think spring batch offers some useful functionality in my case also?
I will be using Quartz as scheduler framework and Hibernate for the database.
Kind Regards
Niels
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hello,
"workflow".
Kind Regards
Niels
Hello Ben,
Thanks for the input. See my previous email with more details. This also explains the choice of the name.
To answer your questions:
batches
Not sure what you mean by that. Will what wait?
That is not something planned, but that is a theoretical possibility.
Not sure what you mean, they are run local but they access and write to remote resources
Yes, you have task types and you specify parameters when you create a task of a certain type
Well, runs are recorded with start and end time and status. Otherwise through logging.
Yes, but the main idea at this moment is that the tasks are part of workflow management. There won't be just a list of tasks. They would be grouped together in to configurations, and the main idea is that each configuration would represent a particular flow of data and metadata, i.e. a layer initially (although the general approach leaves room for other interpretations of what a configuration could be used for. Its main purpose is to provide some intuitive navigation).
Via a webGUI
Kind regards,
Ben.
Hello,
"workflow".
Kind Regards
Niels
through logging.
This answers my first question. :slight_smile:
It still seems to me that "workflow" is a very general term. What workflow patterns <https://en.wikipedia.org/wiki/Workflow_patterns&gt; will you support? Could future extensions support BPEL <https://en.wikipedia.org/wiki/Business_Process_Execution_Language&gt; or YAWL <https://en.wikipedia.org/wiki/YAWL&gt;?
I am not objecting to what you are trying to do, which sounds very useful, just worried that the name might mislead as to scope.
Could your module be described as "stored-procedure" or "server-procedure"?
"There are only two hard things in Computer Science: cache invalidation and naming things. -- Phil Karlton"
https://martinfowler.com/bliki/TwoHardThings.html
Via a webGUI
What I mean to ask is whether the tasks are scripts, REST API calls, pluggable providers, or some means?
Kind regards,
Director
New Zealand
Okay Ben, you make a good case, we can pick another name to avoid confusion.
I'll have a think and discussion about it. "Stored procedure" that reminds me too much of stored procedures in databases though.
ah, pluggable providers.
Regards
Niels
Hello Simone,
I understand your concern. I would also love to get rid of the various code with overlapping functionality and make the geoserver code base more elegant and robust.
In response to the approach "I'll add this one more thing because I need it." It is normal that economically speaking, additions are made to an open-source project on a need-to-have basis. The code I am writing needs to be written either way. So the only choices here are: keep the code private; create a separate (very small, unnoticed) open source project; or donate the code to the geoserver community so that other people who find it useful may use it. It was my choice to rather pick the latter.
That doesn't necessarily mean however that existing functionality should be duplicated, on the contrary. If new functionality is added, it should be optimally integrated with the old functionality.
I have thought about the overlap between importer and the new module. The only thing I see, is as you point out, the existence of a job queue. I would like to think about a way to integrate them, but there are a number of issues with that
* My job queue is far more general than importer, which only supports very specifically defined tasks. Therefore, logically, it would be importer that needs be modified to be built on top of my API rather than me building on top of importer.
* would it still make sense to have this job queue code that supports many kinds of tasks, in a module named "importer"? So then we get a new module on which importer depends rather than the other way around.
* my module will be database-driven, because my data model is far more complicated (there are tasks, batches, and configurations to organise the hundreds of tasks that may exist).
That would imply extra dependencies for hibernate. Same for the scheduler dependencies. Can I enforce these dependencies upon importer when it now works fine without?
* this can be avoided by adding extra abstraction for the job queue which may have a simple and more sophisticated implementation. Then we get two extra modules instead of one. Unless the abstraction and simple implementation could be added to one of the core modules. But then this will require a proposal etc..
So, in practice, this will mean quite a bit more work for me than if I just provide the code as a community module. But that is definitely negotiable. But I do wonder what the community thinks about the issues and options above.
Regards
Niels
On 26-05-17 16:20, Simone Giannecchini wrote:
Ciao Niels,
honestly from the description this seems to add a new module with
functionalities that should IMHO end up in the importer, possibly with
some modifications to the importer itself.
The importer is a small workflow engine and what you are trying to do
looks like an extension to the importer where, for example the ability
to run task periodically rather that on demand.
The importer already has a concept of task chain which could be extended.
As I said,I believe we are continuing to throw in new modules with
duplications and overlaps without trying to make geoserver more
robust:
- we have two mosaics with some overlaps
- we have N ways to do styling, with slight differences, why we don't
make a choice as a project we stick to that and we concentrate efforts
on implementing new feature for rendering and making the current
engine more performant/robust?
- we have 2 plugins for clustering with some overlaps
- we have N xml engines around
I would like to see some effort towards cleaning up duplications and
making geoserver a better product, but it looks like to me the
approach is rather the opposite: I'll add this one more thing because
I need it.
Btw Niels, this is not against you, it is something I have been
thinking about for a while.
According to the rules you are free to go and I won't object if you do.
That said, I think we might need to rethink the rules of comm modules
or at least to ask for a plan to be discussed a little because aside
from having a plethora of additional modules in the codebase so far I
have not seen much additional participation from outsiders (as in new
developers).
I think this is a good topic for a separate thread and a PSC meeting.
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Thu, May 25, 2017 at 12:09 PM, Niels Charlier <niels@anonymised.com> wrote:
this:
and desired.
database.
Kind Regards
Niels
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
Hello,
"workflow".
Kind Regards
Niels
On Mon, May 29, 2017 at 2:55 PM, Niels Charlier <niels@anonymised.com> wrote:
works fine without?
Hibernate... Mind cross module conflicts, monitoring and GeoFence already
use hibernate,
and possibly different versions of it
Ing. Andrea Aime
@geowolf
Technical Lead
I am using the versions specified in the geoserver root pom
  • my module will be database-driven, because my data model is far more complicated (there are tasks, batches, and configurations to organise the hundreds of tasks that may exist).
Hibernate… Mind cross module conflicts, monitoring and GeoFence already use hibernate,
Ing. Andrea Aime
@geowolf
Technical Lead
This sounds like a great option. A modest investment in refactoring now will save us the future maintenance overhead introduced by duplication. (And I speak us someone currently fixing my own ill-considered DataUtilities duplication from five years ago.)
Kind regards,
Director
New Zealand
What is your opinion on the dependency concern?
What do you think of having the new module be called "task manager" or something like that.
Although it will contain a quite a bit of task implementation that regards remote data management specifically. Should I add two new modules though :confused:
Regards
Niels
Kind regards,
So going back to this proposal of last year. I contributed a first batch of code which is inside a new PR. Now this is a new community module that will be fully maintained by me (and fully documented soon as well) so I do not think I technically need approval for the code (although reviews/comments are always more then welcome!) but there are two small changes in the "main module" that I do need approval for. Would there someone will so kind to have a look at them (would only take a few minutes).
These are direct links to the changes in main:
https://github.com/geoserver/geoserver/pull/2759/commits/6945957a93b326ddaa39ee00c3ca4a707d663aee#diff-ed7269d9c2be90db1cbfde7d0f32d751
https://github.com/geoserver/geoserver/pull/2759/commits/6945957a93b326ddaa39ee00c3ca4a707d663aee#diff-5fac1624412cebb8475c6e0fee6fd17c
Kind Regards
Niels
Regards
Niels
Kind regards,
