I'd like to create a new test module in GeoServer community module to test
gt-webservice in Geotools app-schema. The module will have tests similar to
app-schema-test in GeoServer extension, but specific for app-schema data
access with web service backend. That is, testing WFS requests like
getFeature, describeFeatureType, etc. I will call it "web-service-test". I
am not sure what the procedure is, but I'm guessing I should propose it
here, and call for votes?
Rini
View this message in context: http://old.nabble.com/New-community-test-module-tp30402428p30402428.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
I'd give this a +1 if I wasn't involved. But as I would like to expand this proposal, we'll need another vote.
What I would like to do is to have an app-schema container for all the non-core modules that hide out in the app-schema suite. We already use this pattern in extensions. For example:
extensions/app-schema/app-schema-test
Because app-schema is in extensions, we should not put anything there that has not been approved for release. We have (or more precisely, Rini has) one new integration test module. I'd like to put this here:
community/app-schema/webservice-test
And then any new app-schema related modules can start here and follow the usual process for promotion to extensions.
Sound OK?
Kind regards,
Ben.
On 08/12/10 11:14, Rini Angreani wrote:
Rini
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineering Team Leader
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
On Wed, Dec 8, 2010 at 5:00 AM, Ben Caradoc-Davies
Sounds like a plan. Though I have no idea of what this will be doing.
Testing gt-webservice I guess? Though I have no idea of what
gt-webservice is about at all
Ing. Andrea Aime
Senior Software Engineer
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
This is the non-OGC webservice backend written by Russell Petty (while he was working as a contractor for Geoscience Victoria [Australia]). This plugin is built on app-schema, but instead of using simple feature backends, connects to a generic webservice. The proposed community module contains the GeoServer integration/WFS/encoding tests for this plugin.
Kind regards,
Alright, thanks Ben and Andrea. I will go ahead and do this.
plugin.
Kind regards,
This SF Dev2Dev email is sponsored by:
WikiLeaks The End of the Free Internet
http://p.sf.net/sfu/therealnews-com
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/New-community-test-module-tp30402428p30412787.html
About to do this now. It was held up due to other priorities.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/New-community-test-module-tp6147820p6325986.html
