I'd like to propose (and implement) a new feature for the GeoServer
configuration,
the ability to hide a layer from the capabilities: simple checkbox
making the layer
available, or not.
A hidden layer can be useful in some cases:
- the layer should be part of a group, but we want to show the group,
not the inner
layers, to the world
- the layer is temporary and somehow linked to a user session, we don't want
to show it to the wide world yet we need it to be around and usable from
OGC service calls
- the layer is going to stay there, but it's a service one, something that a
particular application uses under covers but that we don't want normal clients
to see and use (not for security issues, but just to avoid
making the capabilities contents too verbose/confusing)
The idea would be to add the flag to LayerInfo, as a new method in the API.
Yet I'd need to have this in 2.1.x too (this would be a sponsored feature),
and we have had a number of these issue in the past... I think I have
a solution:
- on 2.1.x add the property in the interface, but make it a derived one picking
on the user map
- on trunk add the field as a Boolean, and inspect the user map as a fallback
when the field is not set
Opinions?
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
+1 on the idea, i actually ran into this problem recently and this would have been quite useful. So I guess this means all the capabilities transformers will have to be updated as well… which at this point is quite a few. And what does “hidden” mean when it comes to the other requests… GetFeature, GetMap, etc… should the services check the hidden flag when those resources are accessed individually?
The idea I had before was to try and use a thread local catalog approach to this, similar to how the virtual services hide layers not in the local workspace. Basically an filter/callback/etc… would set up a thread local view of the catalog (with a custom resource access manager, etc…) that would prevent access to hidden layers. The benefit of this approach being that no service code would really have to be updated at all.
$0.02
-Justin
On Tue, Sep 6, 2011 at 1:22 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
I’d like to propose (and implement) a new feature for the GeoServer
configuration,
making the layer
available, or not.
not the inner
- the layer is temporary and somehow linked to a user session, we don’t want
OGC service calls
- the layer is going to stay there, but it’s a service one, something that a
particular application uses under covers but that we don’t want normal clients
Yet I’d need to have this in 2.1.x too (this would be a sponsored feature),
and we have had a number of these issue in the past… I think I have
a solution:
on the user map
Opinions?
Ing. Andrea Aime
Tech lead
Special Offer – Download ArcSight Logger for FREE!
Finally, a world-class log management solution at an even better
price-free! And you’ll get a free “Love Thy Logs” t-shirt when you
download Logger. Secure your free ArcSight Logger TODAY!
http://p.sf.net/sfu/arcsisghtdev2dev
Geoserver-devel mailing list
Justin Deoliveira
OpenGeo - http://opengeo.org
On Tue, Sep 6, 2011 at 4:57 PM, Justin Deoliveira <jdeolive@anonymised.com> wrote:
transformers will have to be updated as well... which at this point is quite
a few. And what does "hidden" mean when it comes to the other requests...
GetFeature, GetMap, etc... should the services check the hidden flag when
Hidden would hide just from the capabilities, which yeah, would require the
caps transformers to be modified, but I don't believe it's a big deal, it's
4-5 classes?
But all other code would not be affected, you'd see the layer directly.
workspace. Basically an filter/callback/etc... would set up a thread local
view of the catalog (with a custom resource access manager, etc...) that
Right... check if the current request is GetCapabilities and make those
layers disappear.
Would work indeed. Wondering, that would start making for the third
wrapper around the catalog... sounds like we need some sort of
extension point for catalog interceptors?
Ing. Andrea Aime
Tech lead
Nice feature Andrea,
Thanks for continuous improvements
2011/9/6 Andrea Aime <andrea.aime@anonymised.com>
caps transformers to be modified, but I don’t believe it’s a big deal, it’s
4-5 classes?
But all other code would not be affected, you’d see the layer directly.
Right… check if the current request is GetCapabilities and make those
layers disappear.
wrapper around the catalog… sounds like we need some sort of
Ing. Andrea Aime
Tech lead
Francesco Izzi
CNR - IMAA
geoSDI
Direzione Tecnologie e Sviluppo
C.da S. Loja
85050 Tito Scalo - POTENZA (PZ)
Italia
phone: +39 0971427305
fax: +39 0971 427271
mob: +39 3203126609
mail: francesco.izzi@anonymised.com
skype: neofx8080
web: http://www.geosdi.org
On Tue, Sep 6, 2011 at 10:32 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
4-5 classes?
Ok, maybe “hidden” is not the best term then. Maybe something like “isDeclared” or something… just brainstorming.
layers disappear.
Yeah agreed. Good idea. It would be nice to have one resource wrapper capable of hiding resources based on the extension point.
Ing. Andrea Aime
Tech lead
Justin Deoliveira
On Wed, Sep 7, 2011 at 2:05 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
4-5 classes?
Ok, maybe "hidden" is not the best term then. Maybe something like
"isDeclared" or something... just brainstorming.
How about "listed"
Advertised?
Ing. Andrea Aime
Tech lead
On Wed, Sep 7, 2011 at 7:08 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
4-5 classes?
How about “listed”
Advertised?
Yup, like this one the best.
Ing. Andrea Aime
Tech lead
Justin Deoliveira
