one year ago we tried to define a list of requirements and wishes
that a new UI framework should satisfy in order to be used for
the GeoServer UI remake. Analysys did not go so well, mainly because
at the time only one candidate (Wicket) was found satisfying all
requirement, and apparently there was not enough interest in redoing
the UI to invest on it.
One year has passed and a few things have changed. Moreover, some
of us believe that the June sprint could be a nice occasion to
switch the UI to a new framework, meaning that we need a decision
on what we're going to use.
Now, we can have a list of "requirements", but no framework will,
in general, satisfy them all. Also, not every developer will
feel the same about each item importance.
So what about coming up with a list of items, and then have
the developers that are really going to use the framework to do the UI
can do a vote?
Here is my list of wishes, sorted in order of importance, on the web
framework that we'll be using:
0) Open source
1) active, big community, very likely to be still around in the next
5 years
2) supports internationalization
3) allows the development of a modular UI, that is, an UI
where pages and components are located in the JARS, as opposed
to being stored in a single place, the web application itself.
This allows for new service UI to be plugged in, as well as
datastore specific UI pages, or service specific extensions
to the feature type configuration page (think of the current
page, but with WFS,WMS,WPS tabs for the configuration elements
that are relevant only to a specific service)
4) good documentation, either has top notch web documentation or
a few up to date books on it
5) fast development, meaning tool support in Eclipse, good
error reporting, fast development turnaround
6) easy to learn for a java developer. The main user for it will
be a java developer that has to do some UI in order to expose
the configuration, he won't be an HTML/javascript/XML wizard
7) compact, ideally would need just the definition of a template
and a backing class to control its contents and navigation
8) possibly with a small payload in terms of jars to be
included in GeoServer (GeoServer is at the moment around
30MB, let's try to avoid jumping to 50)
9) possibly does not require JDK, but works with JRE instead
(so that we can distribute an installer with everything
included)
10) (very personal) with as less XML as possible around
Wondering, what are other people's ones?
One thing to notice is that requirement 3) is what kills most
of the web framework, in that it's impossible to attain, or
it's possible but makes development quite a bit harder.
Dropping it would open the gate to a wider list of
frameworks... what is other developer's opinion on it?
I cannot really think like dropping the requirement, since
I don't see how we could have a per datastore config page
or how could we allow the development of new custom services
outside of the geoserver code base. Yet I'm curious about
hearing other people opinions.
