On Wed, Sep 30, 2015 at 8:23 AM, Jody Garnett <jody.garnett@anonymised.com>
wrote:
On the bright side CITE tests past, and I will go through the steps of
releasing tomorrow against repo.boundlessgeo.com.
Hi Jody, I'd advise care, it seems the geotools jars are a few days old,
the latest snapshot there is now from the 26th:
http://repo.boundlessgeo.com/main/org/geotools/gt-main/14-SNAPSHOT/
I've kicked manually a GeoTools build, hopefully that will fix it and ...
ouch, I see the release build is running,
but you're probably working against old revisions...
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
