Dear All,
quick observation, this small change is useful for people using REST
routinely to publish/configure data.
Checking if a resource exists using a GET call on it causes GeoServer
to fill the log with useless exceptions right now. Adding a quick
parameter like the one proposed by Nicola
has the objective to fix this situtation without a deep modification.
In the longer run we want to expose filtering/sorting/paging through
REST interface as well so that one could actually make searches using
CQL filters rather than seding direct GET queries to check if a REST
resource exists or not.
If you check the PR is small although it touches many Finders; it also
comes with tests and documentation update.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via Poggio alle Viti 1187
mob: +39 333 8128928
nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del
messaggio, per le finalità indicate nel messaggio stesso. Qualora
riceviate questo messaggio senza esserne il destinatario, Vi preghiamo
cortesemente di darcene notizia via e-mail e di procedere alla
distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità
diverse, costituisce comportamento contrario ai principi dettati dal
D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely
for the attention and use of the named addressee(s) and may be
confidential or proprietary in nature or covered by the provisions of
privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New
Data Protection Code).Any use not in accord with its purpose, any
disclosure, reproduction, copying, distribution, or either
dissemination, either whole or partial, is strictly forbidden except
previous formal approval of the named addressee(s). If you are not the
intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message
that has been received in error. The sender does not give any warranty
or accept liability as the content, accuracy or completeness of sent
messages and accepts no responsibility for changes made after they
were sent or for other risks which arise as a result of e-mail
transmission, viruses, etc.
On Fri, Sep 19, 2014 at 12:11 PM, Nicola Lagomarsini
<nicola.lagomarsini@anonymised.com> wrote:
I would like to propose a new parameter for the REST GET method. This
parameter is called quietOnNotFound and would be used to avoid logging
exceptions thrown when a Resource has not been found.
Note that the 404 HTTP status will be returned anyway.
The default value will be false, which means that exceptions will be logged.
I'm asking if you can accept this little change or if you have any question
about it.
I'm also asking if I could backport this change on the 2.6.x branch, after
2.6.0 is released.
Best Regards,
Nicola Lagomarsini.
Ing. Nicola Lagomarsini
Junior Software Engineer
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.
information in this message that has been received in error. The sender does
not give any warranty or accept liability as the content, accuracy or
Slashdot TV. Video for Nerds. Stuff that Matters.
http://pubads.g.doubleclick.net/gampad/clk?id=160591471&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Simone Giannecchini
@simogeo
Founder/Director
D.Lgs. 196/2003.
On Fri, Sep 19, 2014 at 2:40 PM, Nicola Lagomarsini
For your information, I have already opened a
JIRA(https://jira.codehaus.org/browse/GEOS-6681) and prepared the pull
request (https://github.com/geoserver/geoserver/pull/751).
Nicola Lagomarsini.
2014-09-19 12:11 GMT+02:00 Nicola Lagomarsini
<nicola.lagomarsini@anonymised.com>:
logged.
question about it.
2.6.0 is released.
Best Regards,
Nicola Lagomarsini.
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il loro
