I am looking at creating a new plugin for the Geoserver web coverage service branch.
Is there any documentation, guides, steps which can guide me in doing so?
Thanks in advance.
Jonathan Wong
jwong@anonymised.com
Thanks in advance.
Jonathan Wong
What kind of plugin? If it's just a new coverage format then check the GeoTools docs and examples.
If it's more extensive, you'll want the 1.4.x branch, see: http://docs.codehaus.org/display/GEOSDEV/Home Particularly: http://docs.codehaus.org/display/GEOSDEV/3+A+Simple+PlugIn and indeed most all of: http://docs.codehaus.org/display/GEOSDEV/4+Programmers+Guide
But the best thing to do is probably just to describe what you're thinking of doing, and some kind people on the list may help out with suggestions.
best regards,
Chris
Jonathan Wong wrote:
Thanks in advance.
Jonathan Wong
jwong@anonymised.com <mailto:jwong@anonymised.com>!DSPAM:1003,44c7db4d36661775926497!
opinions on IT & business topics through brief surveys -- and earn cash
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV!DSPAM:1003,44c7db4d36661775926497!
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1003,44c7db4d36661775926497!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Hi Jonathan,
Here is a tutorial on how to write a simple plugin.
But, depending on what type of plugin you want to create, the wcs stuff may or may not be set up to be pluggable.
Can you describe a little bit about what you want to do?
Thanks.
-Justin
Thanks in advance.
Jonathan Wong
jwong@anonymised.com <mailto:jwong@anonymised.com>!DSPAM:1004,44c7db4e36701116498154!
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV!DSPAM:1004,44c7db4e36701116498154!
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,44c7db4e36701116498154!
Justin Deoliveira
jdeolive@anonymised.com
Ciao Jonathan,
could you provide a bit more details about your intentions,objective,
level of involvement, time plan?
Afterwards we could discuss on how to help you out with this.
SImone.
On 7/25/06, Jonathan Wong <jwong@anonymised.com> wrote:
branch.Is there any documentation, guides, steps which can guide me in doing so?
Thanks in advance.
Jonathan Wong
jwong@anonymised.com-------------------------------------------------------------------------
http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV_______________________________________________
Simone Giannecchini
Software Engineer
Freelance Consultant
Hi Simone,
I am looking at creating a plug-in for Geoserver WCS branch. I want to create a new plug-in so the request getCoverage can support a new file format. So far, I've worked out I have to implement these four interfaces from GeoTools,
Format, GridCoverageReader, GridCoverageWriter, GridCoverageFactorySpi.
Wrap them up in a jar, put it on the classpath and Geoserver will do the rest.
I was hoping someone could point me to some documentation which gives any more advice, technical details of successfully creating a plug-in.
Jonathan Wong
On 27 Jul 2006, at 15:27, Simone Giannecchini wrote:
Ciao Jonathan,
level of involvement, time plan?Afterwards we could discuss on how to help you out with this.
SImone.
Thanks in advance.
Jonathan Wong
https://lists.sourceforge.net/lists/listinfo/geoserver-devel--
Simone Giannecchini
Software Engineer
Freelance Consultant°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°°
