[Geoserver-devel] New PNG encoder: how about a GSIP to merge it into core on trunk?
thinking about the new PNG encoder, I was wondering, what if I make a GSIP to include it
on trunk as the default PNG encoder (so move the code in the wms module),
replacing also the usual checkbox about choosing the
“native” PNG encoder with a combo box with a drop down having 3 options, jdk, native
or PNGJ.
Rationale:
  • the new PNG encoder is pure java, requires no extra installations, and provides both performance
    and output size benefits
  • has a good amount of testing, with checks it can encode more color models than GeoServer
    normally produces in output (all the ones contained in the PNG spec)
  • we still have three+ months ahead before the 2.5.0 release, so there is time to kick its tires
  • for any residual corner case the drop down choice will allow admins to switch to another
    encoder
I understand this encoder is “new”, but so were the new KML module and the new shapefile
modules last release (so far it seems it went well for those two, only a few issues were reported),
and that’s precisely the reason for a GSIP.
Just wanted to test the waters and see if anyone would be strongly opposed to the move.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I would bee keen to see it land as an option in trunk. I would like it if we could strike a balance between discussion and breaking out a GSIP proposal.
I do not see this change as particularly strategic, destabilising, or as a scary API or UI change. It looks like exactly the kind of RnD we expect on trunk and think we could proceed based on discussion.
Jody Garnett
On Mon, Nov 25, 2013 at 4:34 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
or PNGJ.
Rationale:
    encoder
Ing. Andrea Aime
@geowolf
Technical Lead
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
No objection here to making it the default on trunk. Imo now is the best time to do it, while we are in dev phase.
On Mon, Nov 25, 2013 at 3:28 AM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Jody Garnett
or PNGJ.
Rationale:
    encoder
Ing. Andrea Aime
@geowolf
Technical Lead
I am also +1 on making the new encoder the default on master. I think a GSIP is required.
I appreciate Jody's caution about making brand new code the default for core functionality; in general, a gradual transition is a good practice. However:
(1) this is only an implementation change and does not alter interface or formats,
(2) the new implementation offers benefits to pure Java users,
(3) making it the default on master makes adoption more likely, as non-default behaviour is often not tested, and
(4) the timing (well before 2.5.0) is just great! If we were a month out, I would be resistant about making this the default on master, but this time scale will give it a decent test.
Andrea also has support on the users list.
I would be +1 to make the new encoder an option on master right now without a GSIP.
Kind regards,
Ben.
    a GSIP proposal.
    Jody Garnett
    <andrea.aime@anonymised.com <mailto:andrea.aime@anonymised.com>>
    wrote:
        module),
        "native" PNG encoder with a combo box with a drop down having 3
        or PNGJ.
        Rationale:
        * the new PNG encoder is pure java, requires no extra
        * has a good amount of testing, with checks it can encode more
        PNG spec)
        * we still have three+ months ahead before the 2.5.0 release, so
        * for any residual corner case the drop down choice will allow
           encoder
        I understand this encoder is "new", but so were the new KML
        and that's precisely the reason for a GSIP.
        Ing. Andrea Aime
        @geowolf
        Technical Lead
        phone: +39 0584 962313 <tel:%2B39%200584%20962313>
        fax: +39 0584 1660272 <tel:%2B39%200584%201660272>
        mob: +39 339 8844549 <tel:%2B39%20%C2%A0339%208844549>
        innovation.
        game-changing
        Sign up now.
        <mailto:Geoserver-devel@lists.sourceforge.net>
    game-changing
    up now.
*Justin Deoliveira*
jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
@j_deolive <https://twitter.com/j_deolive&gt;
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
When playing with the code I created a 4 bit grayscale image.
The reason I use ushort is because it results in better quality images than if I use byte (I had issues with lines not drawing smoothly).
BufferedImage bi = ImageTypeSpecifier
.createGrayscale(4, DataBuffer.TYPE_USHORT, false)
.createBufferedImage(width, height);
The ScanlineProviderFactory didn’t like this because of the use of USHORT in combination with an IndexColorModel.
One thing I needed to do to get it to work is create a constructor on RasterShortSingleBandProvider which takes a bit depth (4 in this case).
Looking at the code, can the final <else if> ever work?
The previous <else if> checks if the ColorModel is an instance of IndexColorModel and then the next <else if>,
knowing that it isn’t an IndexColorModel, casts the ColorModel to IndexColorModel.
I hope this helps.
Simon Hartley
From: Andrea Aime [mailto:andrea.aime@anonymised.com]
Sent: 24 November 2013 17:34
To: Geoserver-devel
Subject: [Geoserver-devel] New PNG encoder: how about a GSIP to merge it into core on trunk?
or PNGJ.
Rationale:
encoder
Ing. Andrea Aime
@geowolf
Technical Lead
*** This communication has been sent from World Fuel Services
Corporation or its subsidiaries or its affiliates for the intended recipient
only and may contain proprietary, confidential or privileged information.
If you are not the intended recipient, any review, disclosure, copying,
use, or distribution of the information included in this communication
and any attachments is strictly prohibited. If you have received this
communication in error, please notify us immediately by replying to this
communication and delete the communication, including any
attachments, from your computer. Electronic communications sent to or
from World Fuel Services Corporation or its subsidiaries or its affiliates
may be monitored for quality assurance and compliance purposes.***
On Fri, Nov 29, 2013 at 12:06 PM, Simon Hartley <SHartley@anonymised.com>wrote:
                                                .createGrayscale(4,
Weird setup indeed. Yes, what you propose should work.
More in general, this PNG encoder should probably have a fallback mode, if
we cannot create a scanline provider,
it should fall back on the JDK one I guess, to make sure it does not break
when plugging custom raster sources
like yours.
Looking at the code, can the final <*else if*> ever work?
The previous <*else if> *checks if the ColorModel is an instance of
IndexColorModel and then the next <*else if>*,
IndexColorModel.
No, you're right, it does not. Weird, I guess none of the official PNG
color models ever get there
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Just for some insight:
I was trying to optimise file size by using a 4 bit palette and this was a suitable and simple way of doing so.
Another tip I found was to avoid the use of anti-aliasing, because it ends up generating intermediate colours, which makes PNG compression more difficult even though the palette bit-depth hasn’t changed.
When testing with native JAI and I/O, I found that when using a non-standard case, Sun/Oracle don’t seem to bother optimising. Judging by the file sizes, they fall back to non-native.
Simon
From: andrea.aime@anonymised.com [mailto:andrea.aime@…403…] On Behalf Of Andrea Aime
Sent: 29 November 2013 11:16
To: Simon Hartley
Cc: Geoserver-devel
Subject: Re: [Geoserver-devel] New PNG encoder: how about a GSIP to merge it into core on trunk?
On Fri, Nov 29, 2013 at 12:06 PM, Simon Hartley <SHartley@anonymised.com> wrote:
More in general, this PNG encoder should probably have a fallback mode, if we cannot create a scanline provider,
it should fall back on the JDK one I guess, to make sure it does not break when plugging custom raster sources
like yours.
No, you’re right, it does not. Weird, I guess none of the official PNG color models ever get there
Ing. Andrea Aime
@geowolf
Technical Lead
