[Geoserver-devel] New postgis+feature pregeneralized tutorial ?
Hi , first thanks a lot for this awesome tutorial.
I need futher informations concerning your *.xml file.
I don't understand the dataSourceNameSpace="n50"
dataSourceName="postgis_n50"
Is it the database schema and the postgis table's name ?
I read this into the general Feature-Pregeneralized tutorial
The dataSourceName attribute in the XML config is not interpreted as a name,
it could be the URL for a shape file or for a property file containing
properties for data store creation (e. g. jdbc connect parameters).
Do i need to create another file that make the link between my postgis
database and the XML file?
Regards
jonathan
Jody Garnett-3 wrote:
At least a blog post :slight_smile:
And grab the instructions for your module docs.
Jody
On 10/06/2010, at 11:10 PM, christian.mueller@anonymised.com wrote:
A user has investigated into these two topics and after one bugfix, he
is up and running. He documented the setup in the attached html file.
Should we make a tutorial based on this material ?.
Geoserver or Geotools documentation ?.
I would prefer sphinx, so Geoserver is my favorite.
This message was sent using IMP, the Internet Messaging Program.
<pregen_tutorial.html>------------------------------------------------------------------------------
ThinkGeek and WIRED's GeekDad team up for the Ultimate
GeekDad Father's Day Giveaway. ONE MASSIVE PRIZE to the
lucky parental unit. See the prize list and enter to win:
http://p.sf.net/sfu/thinkgeek-promo_______________________________________________
Geoserver-devel mailing list
View this message in context: http://old.nabble.com/New-postgis%2Bfeature-pregeneralized-tutorial---tp28842935p28956663.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
