I can't compile geoserver from the svn.
When I launch "mvn compile" it aborts because it can't download
gt2-demo-property-2.3-SNAPSHOT.
Where can I find it ?
Hi Nicola,
What branch are you working from. It sounds like you are working against
wcs since this is a geotools trunk dependency. I don't believe anyone is
deploying the geotools trunk snapshots regularly at the moment.
So one option is to check out the geotools trunk and build it locally. I
will try to get around to deploying a trunk snapshot today.
-Justin
Nicola Racco wrote:
Where can I find it ?-------------------------------------------------------------------------
Using Tomcat but need to do more? Need to support web services, security?
Get stuff done quickly with pre-integrated technology to make your job easier
Download IBM WebSphere Application Server v.1.0.1 based on Apache Geronimo
http://sel.as-us.falkag.net/sel?cmd=lnk&kid=120709&bid=263057&dat=121642
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,44f7e89b201741460912952!
Justin Deoliveira
The Open Planning Project
jdeolive@anonymised.com
Hi Nicola:
Justin is right--if you want to compile the WCS-1.4.x branch of
Geoserver you need to check out and compile gt-trunk first.
Alex
On 9/1/06, Justin Deoliveira <jdeolive@anonymised.com> wrote:
Hi Nicola,
deploying the geotools trunk snapshots regularly at the moment.So one option is to check out the geotools trunk and build it locally. I
will try to get around to deploying a trunk snapshot today.-Justin
Nicola Racco wrote:
> Hi all,
Justin Deoliveira
jdeolive@anonymised.com-------------------------------------------------------------------------
FYI,
I just deployed a trunk snapshot so you should be able to build now
without a local checkout. It might be nice to set something up where we
can deploy geotools regularly so that people dont have to constantly
build it.
-Justin
Alexander Petkov wrote:
Hi Nicola:
Geoserver you need to check out and compile gt-trunk first.Alex
Hi Nicola,
Nicola Racco wrote:
https://lists.sourceforge.net/lists/listinfo/geoserver-devel--
Justin Deoliveira
https://lists.sourceforge.net/lists/listinfo/geoserver-devel-------------------------------------------------------------------------
https://lists.sourceforge.net/lists/listinfo/geoserver-devel!DSPAM:1004,44f85349248581527717022!
Justin Deoliveira
