[Geoserver-devel] Nightly 2.6.x and 2.5.x failing for 11 days
Nightly 2.6.x and 2.5.x have been failing for 11 days. Looks like a failure in community/dds.
Fix or kick?
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Mineral Resources Flagship
Australian Resources Research Centre
community module - kick
Jody Garnett
On Sun, Sep 14, 2014 at 11:14 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Fix or kick?
Ben Caradoc-Davies Ben.Caradoc-Davies@anonymised.com
Software Engineer
Want excitement?
Manually upgrade your production database.
When you want reliability, choose Perforce
Perforce version control. Predictably reliable.
http://pubads.g.doubleclick.net/gampad/clk?id=157508191&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
I have now also found the DDS/BIL thread:
http://osgeo-org.1560.x6.nabble.com/Failing-tests-in-DDS-BIL-module-td5161559.html
What I do not understand is why this is failing on 2.6.x and 2.5.x but not on master. Seems a bit odd to kick them off stable/maintenance while keeping them on master.
Kind regards,
Ben.
Jody Garnett
<Ben.Caradoc-Davies@anonymised.com <mailto:Ben.Caradoc-Davies@anonymised.com>> wrote:
    Fix or kick?
    Software Engineer
    Want excitement?
    <mailto:Geoserver-devel@lists.sourceforge.net>
Software Engineer
Oh, my.
geoserver-master-nightly is running with -DskipTests which explains why it has no test failures.
Should we be using this on 2.5.x and 2.6.x nightlies as well?
Kind regards,
Ben.
not on master.
Software Engineer
Yes we should skipping tests for nightlies, just added the flag to 2.5.x and 2.6.x. Sorry, I missed it yesterday when i was fixing the builds.
On Sun, Sep 14, 2014 at 11:59 PM, Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com> wrote:
Oh, my.
Kind regards,
Ben.
not on master.
Software Engineer
Want excitement?
Justin Deoliveira
VP Engineering | Boundless
jdeolive@anonymised.com
@boundlessgeo
Thanks, Justin. That should do the trick. I was not sure if there was something special that had changed. We will see if they are fixed in a few hours.
I preened the maven options on all three branches to make them identical; geoserver-master-nightly was running assembly:attached twice. We will know very soon if I broke anything.
Kind regards,
Ben.
    Oh, my.
    Kind regards,
    Ben.
    > What I do not understand is why this is failing on 2.6.x and 2.5.x but
    > not on master.
    Software Engineer
    Want excitement?
Justin Deoliveira
VP Engineering | Boundless <http://boundlessgeo.com/&gt;
jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>
@boundlessgeo <http://twitter.com/boundlessgeo/&gt;\*
Software Engineer
Wrong! geoserver-nightly-master was the only one that correctly runs assembly:attached for the top-level pom. (Pressing the Advanced button reveals the second goal was for community/pom.xml, so this was not a duplicate.)
I added assembly:attached for all branch nightlies to try to fix geoserver-2.5.x-nightly and geoserver-2.5.x-nightly and kicked the latter.
Fingers crossed ...
Software Engineer
