[Geoserver-devel] nightly build on windows
I just grabbed the nightly build in order to test wfs-t (I seem to
have missed the testing week after all). Out of the box the nightly
build fails ... see log at the end of this message.
When I have a global GEOSERVER_DATA_DIR set (thanks to Mikes GeoServer
2.0.0 installer) the nightly build works fine. So the code is working
but something is up with the data directory provided?
Jody
------------------------------------------log------------------------------------------
Welcome to GeoServer!
JAVA_HOME: C:\Program Files\Java\jdk1.6.0_16
The GEOSERVER_HOME environment variable is not defined correctly.
Temporarily setting GEOSERVER_HOME to the following directory:
C:\geoserver-2.0.1
Please wait while loading GeoServer...
1 [main] INFO org.mortbay.log - Logging to
org.slf4j.impl.SimpleLogger@anonymised.com via org.mortbay.log.Slf4jLog
204 [main] WARN org.mortbay.log - Deprecated configuration used for
C:\geoserver-2.0.1/webapps
233 [main] INFO org.mortbay.log - jetty-6.1.808/01/2010 8:14:28 PM
it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no
gdaljni in java.library.path
0 [main] WARN org.geoserver.logging - Could not find
configuration file for logging
1399 [main] INFO /geoserver - Initializing Spring root WebApplicationContext
743 [main] ERROR org.vfny.geoserver.global -
- GEOSERVER_DATA_DIR: C:\geoserver-2.0.1\webapps\geoserver\data
792 [main] ERROR org.geowebcache.storage.DefaultStorageFinder -
Found Servlet context parameter GEOSERVER_DATA_DIR set to C:\Program
Files\GeoServer 2.0.0\data_dir , but this path does not exist
4585 [main] WARN org.geoserver - No 'workspaces' directory found,
unable to load any stores.
7360 [main] INFO org.mortbay.log - Opened
C:\geoserver-2.0.1\logs\2010_01_08.request.log
7376 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8080
