On Fri, Mar 18, 2016 at 1:40 AM, Ben Caradoc-Davies <ben@anonymised.com>
wrote:
I increased the nightly build heap to -Xmx2048m to fix them. I usually
need this flag to build -PcommunityRelease locally. It does seem excessive.
Wow yeah it does. Thanks for fixing the nightly builds.
Do you have any clue as to why it's going OOM, and if any particular module
is responsible for that?
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
