Hi Jody,
thanks for doing that, gave it a quick spin!
The command for running it lacks a backslash on the first line:
docker run -it -p8080:8080 docker.osgeo.org/geoserver:2.24.x
–env INSTALL_EXTENSIONS=true
–env STABLE_EXTENSIONS=“css,wps”
–env COMMUNITY_EXTENSIONS=“ogcapi-features”
But… even this way, the extensions are not getting installed… then noticed the docker image reference
appears twice. This works (docker image reference only at the end):
docker run -it -p8080:8080 docker.osgeo.org/geoserver:2.24.x --env INSTALL_EXTENSIONS=true --env STABLE_EXTENSIONS=“css,wps” --env COMMUNITY_EXTENSIONS=“ogcapi-features” docker.osgeo.org/geoserver:2.24.x
Noice!
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
