Can you talk about what you were accomplishing with this commit? Is it something we should revert on master and reapply after Kevin’s branch is merged?
With a bit more looking, I’m getting the same unit test failure when I build straight from master so it doesn’t actually seem to be related to my pull request.
Failed tests: testHarvestImageMosaicWithDirectory(org.geoserver.catalog.rest.CoverageStoreFileUploadTest): expected:<…-11-01T00:00:00.000Z[,2008-11-02T00:00:00.000Z]> but was:<…-11-01T00:00:00.000Z>
Jody Garnett
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration http://p.sf.net/sfu/hpccsystems
the test failure that Kevin reported should be caused by an older version of the gt-imagemosaic module, so I think Kevin should update the master branch of geotools in order to get the updates for that module. If the test failure continues to exist, I will investigate on it.
Anyway I noticed that the GeoServer Jenkins build is not broken now.
GeoServer Professional Services from the experts! Visit http://goo.gl/NWWaa2 for more information.
Ing. Nicola Lagomarsini
Junior Software Engineer
Via Poggio alle Viti 1187
Jody Garnett
On Wed, Jun 11, 2014 at 9:57 AM, Nicola Lagomarsini <
nicola.lagomarsini@anonymised.com> wrote:
Also verified locally, a full build of geotools and geoserver works fine
here
Ing. Andrea Aime @geowolf
Technical Lead
mob: +39 339 8844549
Also verified locally, a full build of geotools and geoserver works fine here
Ing. Andrea Aime
@geowolf
Technical Lead
Ing. Andrea Aime
@geowolf
Technical Lead
