Can you give an example how to use it? The example I posted doesn't
seem to work at all.
What coordinate system are you using? The problem is, I belive, that
its not properly looking at the maps coordinate system. In order to
calculate the scale, you basically have to know "one centimeter on the
screen is X centimeters in real life". Calculating both of those
numbers isnt trivial.
dave
This mail sent through IMP: https://webmail.limegroup.com/
