[Geoserver-devel] (no subject)
The "preview" screen does work on the .exe version of Geoserver
1.3.0RC3, so this is possibly a Linux problem.
NOTE: justin tried it on unix and it worked fine.
If you're using the GEOSERVER_DATA_DIR then thats probably your problem;
mapbuilder requires HTTP access to the files which isnt possible when
you use GEOSERVER_DATA_DIR. I've reported this problem (expressed in
other ways) before.
This version of preview is very simple - the next release will have a
more functional version.
The first line and a bit of the linux startup.sh is:
#!/bin/sh
In hex its:
23 21 2F 62 69 6E 2F 73 68 0A 23 20 2D ...
# ! / b i n / s h LF # <sp> -
Justin said he didnt see any problems in the file under linux (and
TextPad says its a unix file). Perhaps this has something to do with
the SVN linefeed settings?
I dont think I can change file permissions to +x in windows and we could
be losing it because I build the .tar.gz on a windows box. I think we
have to modify the permission in the tar-task's <fileset> tags.
And did we get the new oracle jars in?
Yes (even though it was commited after I tagged).
I assumed we did, since gt was
tagged, but it looks like a vpf fix that I put in to get rid of the
warning message didn't make it. Unless I didn't get it in gt2, but I'm
pretty sure I did.
SVN says the last 2 commits to the vpf directory were:
9/18/05 jgarnett "changed over to 2.1.1"
6/6/05 jgarnett "Move 2.1.x over to building 2.1.RC1"
So, I dont think you commited the change.
dave
This mail sent through IMP: https://webmail.limegroup.com/
other ways) before.
No, no geoserver_data_dir.
Cool.
#!/bin/sh
In hex its:
I'm pretty sure we had to chmod it to do the right permissions. And yes,
it's the linefeed stuff.
I'm pretty sure at some point I successfully had an ant task doing this, I
think you can have set the permissions and do the linefeeds as well.
Perhaps I didn't commit, which seems unlikely, though I feel like lots of
things I committed are weirdly not there, between the datetime stuff and
now vpf. Could also have been blown away...
Cool.
>pretty sure I did.
Weird, maybe I should reinstall svn or something? This one I'm not as
sure as the datetime commit though...
My laptop's broken, but basically what I was going for is so start up of
geoserver doesn't look like someone yakked. There was a mysql and sde
change as well, but those may have got in, maybe I just didn't get to
vpf...
C
dave
