[Geoserver-devel] (no subject)
Justin,
Sweet - now it *passes* and only takes 1/2 a minutes.
1. create an empty, postgis-enabled DB on your local box
2. edit plugin\postgis\test\org\geotools\data\postgis\fixture.properties
   so that it points to your localhost DB (with correct user/password)
works great!
thanks,
dave
test:match:
    [echo] Searching directory
C:\eclipse\workspace\g2_2_1_x\plugin\postgis\test
    [junit] Running
org.geotools.data.postgis.PostgisDataStoreAPIOnlineTest
    [junit] Tests run: 29, Failures: 0, Errors: 0, Time elapsed: 33.297
sec
This mail sent through IMP: https://webmail.limegroup.com/
