This sounds great and I agree that 'loose-BBox' (default false)
Is a good choice. I'll try to test this as soon as possible although
I'm not too familiar with the cvs etc.
I understand the mechanism whith using both '&&' and 'intersecs()',
still I wonder why it seems as if in the statement this pattern is
repeated twice which ends up with total four conditions.
Best regards,
Peter
Output from Geoserver (simplified):
#SELECT gid, AsText(force_2d("the_geom")), "shape_area"
#FROM "byggnader"
#WHERE (
# "the_geom" && GeometryFromText
# ('POLYGON((x1 y1,x1 y2,x2 y2,x2 y1,x1 y1))',srid)
# AND
# intersects("the_geom", GeometryFromText
# ('POLYGON((x1 y1,x1 y2,x2 y2,x2 y1,x1 y1))',srid))
# AND
# AND
Ok, this is in geotools svn (on 2.0.x branch) and geoserver cvs. I went
with loose bbox. Setting it to true will do the query with just the
&&, speeding it up a bit. Not as deadly accurate, but faster. Should
be an option in the web admin interface now. I'll try to get a release
out sometime next week.best regards,
Chris
Quoting Chris Holmes <cholmes@anonymised.com>:
> Funny you should ask this right now. I'm half way through
> implementing an
> option in the PostGIS DataStore to specify exactly this.
> You are correct, intersects does not use the GiST index, as far as I
> know,
> and the && operator does. That's why the && operator is used in
> conjunction with the intersects(), so as to make use of the index
> before
> attempting the intersects operation.
> The weakness of the && operator is that it is not exactly correct.
> As you
> say, it does more or less the same thing. The difference is it just
> uses
> the bounding box of the geometries, instead of the actual geometries,
> causing it to be wrong is some cases.
> But some people, like you I imagine, and like most WMSes, don't
> really
> care so much about that. Which is exactly why I coded up the option
> (just
> for the Bounding Box filter, may consider doing it for other filters,
> but
> I'm not sure how I feel about that) to specify which one you want.
> I finished the implementation in postgis gt2 2.0.x filter, I just
> need to
> include it in the factory. If you can work off of cvs I can probably
> get
> it up in a day or two (I'm on dial up at the moment, so things are
> slower).
> And I'd like feedback on the name you prefer, I'm thinking either
> 'loose-BBox' or 'strict-BBox' (both would be true/false, and have the
> opposite meaning). When done users can specify this in the geoserver
> admin interface.
> The code for the filter is in the geotools subversion
> (http://svn.geotools.org - in the 2.0.x branch) repository, you can
> get it
> right away and set 'looseBbox' to true, build with maven and plug in
> to
> GeoServer and it'll get the behaviour you'd like right away.
> Chris
> ----- Original Message -----
> From: "Peter Segerstedt" <petersegerstedt@anonymised.com>
> To: <geoserver-devel@lists.sourceforge.net>
> Sent: Thursday, September 16, 2004 1:10 PM
> Subject: Re: [Geoserver-devel] Non-optimized SQL-statements?
> > Oops, I seem to have missed a '2' when I copied the output (I've
> corrected
> > it below).
> > No, they are two identical pairs of conditions, actually I think
> all of
> the
> > four conditions in variant 1 are equal which in that case means
> that
> they
> > could all be replaced by one of them. The operation '&&' (overlaps)
> and
> the
> > function 'intersects()' seems to do the same job, just that for
> some
> reason,
> > 'intersects()' in my case doesn't use the gist-index. The
> performance
> > (counted in time) differs by a factor 9 in my simple test.
> > /Peter
> > >From: Alexandre Florio <aflorio@anonymised.com>
> > >To: geoserver-devel@lists.sourceforge.net
> > >Date: Thu, 16 Sep 2004 09:52:53 -0300
> > > Aren't the queries different?
> > > In the first query you are intersecting with 2 geometries
> (SRID=2400
> > >and 400), and in the second one, just with 1 geometry (SRID=2400).
> > >-- Alexandre
> > >Em Thu, 16 Sep 2004 13:57:38 +0200
> > >"Peter Segerstedt" <petersegerstedt@anonymised.com> escreveu:
> > > > # SELECT gid, AsText(force_2d("the_geom")), "shape_area"
> > > > # FROM "byggnader"
> > > > # WHERE (
> > > > # "the_geom" && GeometryFromText('POLYGON ((1332700
> 6174900,
> > >1332700
> > > > 6181900, 1339700 6181900, 1339700 6174900, 1332700 6174900))',
> 2400)
> > > > # AND
> > > > # intersects("the_geom", GeometryFromText('POLYGON
> ((1332700
> > >6174900,
> > > > 1332700 6181900, 1339700 6181900, 1339700 6174900, 1332700
> 6174900))',
> > > > 2400))
> > > > # AND
> 6174900,
> > >1332700
> 6174900))',2400)
> > > > # AND
> ((1332700
> > >6174900,
> 6174900))',
> > >2400))
> > > > When I evaluate the statement in psql using 'EXPLAIN ANALYZE' I
> get
> the
> > > > following result:
> > > > # Index Scan using byggnader_gist_index on byggnader
> (cost=0.00..652.08
> > > > rows=18 width=312) (actual time=0.000..16574.000 rows=9452
> loops=1)
> > > > # Index Cond: (
> > > > # (the_geom && 'SRID=2400;POLYGON((1332700 6174900,1332700
> > > > 6181900,1339700 6181900,1339700 6174900,1332700
> 6174900))'::geometry)
> > > > # AND
> > > > # Filter: (
> > > > # intersects(the_geom, 'SRID=2400;POLYGON((1332700
> 6174900,1332700
> > > > # AND
> > > > # intersects(the_geom, 'SRID=400;POLYGON((1332700
> 6174900,1332700
> 6174900))'::geometry))
> > > > # Total runtime: 17326.000 ms
> > > > From my point of view it seems as if the following statement
> would
> be
> > > > sufficient:
> > > > # FROM "byggnader"
> > > > # WHERE (
> 6174900,
> > >1332700
> 2400)
> > > > ...which results in:
> > >(cost=0.00..32893.03
> > > > rows=8534 width=312) (actual time=0.000..2033.000 rows=9452
> loops=1)
> > > > # Index Cond: (
> > > > # the_geom && 'SRID=2400;POLYGON((1332700 6174900,1332700
> > > > # Total runtime: 2123.000 ms
> > > > Am I totally wrong or is something happening here that maybe
> could
> be
> > > > improved?
> This SF.Net email is sponsored by: YOU BE THE JUDGE. Be one of 170
> Project Admins to receive an Apple iPod Mini FREE for your judgement
> on
> who ports your project to Linux PPC the best. Sponsored by IBM.
> Deadline: Sept. 24. Go here: http://sf.net/ppc_contest.php
> Geoserver-devel mailing list
> Geoserver-devel@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
This mail sent through IMP: https://webmail.limegroup.com/
_________________________________________________________________
Tired of spam? Get advanced junk mail protection with MSN 8. http://join.msn.com/?page=features/junkmail
