[Geoserver-devel] Not able publish the layer in Geoserver
I am using geoserver 2.1.4. I am not able to publish layer and even It does
not throws error.
I debugged in GEOTOOLS_DEVELOPER_LOGGING.PROPERTIES log level.
I show info like the *Read and Write* operation is locked for shapfile.
log file info:
DEBUG [org.geoserver] - Thread 63 got the lock in mode WRITE
DEBUG [org.geotools.data.shapefile] - Read lock:
file:/C:/tomcat/webapps/geoserver/data/data/sample/test.shp by Shapefile
Datastore's getBounds Method
Please reply me,
Thanks
Mano G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Not-able-publish-the-layer-in-Geoserver-tp5097207.html
Sent from the GeoServer - Dev mailing list archive at Nabble.com.
Ciao Mano,
not throws error.
Have you successfully created the store using that shapefile (you are having problems on publishing layer or also creating the store)?
You are using the web interface or the REST one? (if REST please attach the call)
I show info like the Read and Write operation is locked for shapfile.
log file info:
Datastore’s getBounds Method
This is not relevant could you attach a larger piece of log?
You are on Windows so you are using exclusive locks on file, be sure to close all the editors on that shapefile before trying to access with geoserver.
Let me know,
Carlo Cancellieri
Please reply me,
Thanks
Mano G
CenturyLink Cloud: The Leader in Enterprise Cloud Services.
Learn Why More Businesses Are Choosing CenturyLink Cloud For
Critical Workloads, Development Environments & Everything In Between.
Get a Quote or Start a Free Trial Today.
http://pubads.g.doubleclick.net/gampad/clk?id=119420431&iu=/4140/ostg.clktrk
Geoserver-devel mailing list
Dott. Carlo Cancellieri
@cancellieric
Software Engineer
Via Poggio alle Viti 1187
I am attaching full log file here.
I am deployed geoserver 2.1.4 in window server 2008 machine.
I am using jre7 and tomcat 7 window server 2008 machine.
For testing,I tried to publish *tasmania_cities* layer on geoserver .
But this layer not published. I checked in geoserver it shows info like.
2014-02-13 10:50:55,956 DEBUG [org.geotools.data.shapefile] - Read lock:
file:/C:/tomcat/webapps/geoserver/data/data/sf/archsites.shp by
org.geotools.data.shapefile.shp.ShapefileReader
2014-02-13 10:50:55,956 TRACE [org.geotools.data.shapefile] - Shapefile
Reader has been opened. Number open: 1
2014-02-13 10:50:55,956 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/sf/archsites.shx by
org.geotools.data.shapefile.shp.IndexFile
2014-02-13 10:50:55,956 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/sf/archsites.dbf by
org.geotools.data.shapefile.dbf.IndexedDbaseFileReader
2014-02-13 10:50:55,956 TRACE [org.geotools.data.shapefile] - Dbase File
file:/C:/tomcat/webapps/geoserver/data/data/sf/archsites.prj by
org.geotools.data.shapefile.prj.PrjFileReader
2014-02-13 10:50:55,956 TRACE [org.geotools.data.shapefile] - PRJ reader has
2014-02-13 10:50:55,971 DEBUG [org.geotools.data.shapefile] - Read lock:
2014-02-13 10:50:55,971 TRACE [org.geotools.data.shapefile] - PRJ reader has
been closed. Number open: 0
2014-02-13 10:50:55,971 TRACE [org.geotools.data.shapefile] - Dbase File
Reader has been closed. Number open: 0
2014-02-13 10:50:55,971 TRACE [org.geotools.data.shapefile] - Shapefile
2014-02-13 10:50:55,971 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/sf/bugsites.shp by
file:/C:/tomcat/webapps/geoserver/data/data/sf/bugsites.shx by
2014-02-13 10:50:55,971 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/sf/bugsites.dbf by
file:/C:/tomcat/webapps/geoserver/data/data/sf/bugsites.prj by
2014-02-13 10:50:55,987 DEBUG [org.geotools.data.shapefile] - Read lock:
2014-02-13 10:50:55,987 TRACE [org.geotools.data.shapefile] - PRJ reader has
2014-02-13 10:50:55,987 TRACE [org.geotools.data.shapefile] - Dbase File
2014-02-13 10:50:55,987 TRACE [org.geotools.data.shapefile] - Shapefile
2014-02-13 10:50:55,987 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/sf/restricted.shp by
file:/C:/tomcat/webapps/geoserver/data/data/sf/restricted.shx by
2014-02-13 10:50:55,987 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/sf/restricted.dbf by
file:/C:/tomcat/webapps/geoserver/data/data/sf/restricted.prj by
file:/C:/tomcat/webapps/geoserver/data/data/sf/roads.shp by
file:/C:/tomcat/webapps/geoserver/data/data/sf/roads.shx by
file...
file:/C:/tomcat/webapps/geoserver/data/data/sf/roads.dbf by
file:/C:/tomcat/webapps/geoserver/data/data/sf/roads.prj by
2014-02-13 10:50:56,003 DEBUG [org.geotools.data.shapefile] - Read lock:
2014-02-13 10:50:56,003 TRACE [org.geotools.data.shapefile] - Shapefile
2014-02-13 10:50:56,003 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/sf/streams.shp by
file:/C:/tomcat/webapps/geoserver/data/data/sf/streams.shx by
2014-02-13 10:50:56,003 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/sf/streams.dbf by
2014-02-13 10:50:56,003 TRACE [org.geotools.data.shapefile] - Dbase File
file:/C:/tomcat/webapps/geoserver/data/data/sf/streams.prj by
2014-02-13 10:50:56,003 TRACE [org.geotools.data.shapefile] - PRJ reader has
file:/C:/tomcat/webapps/geoserver/data/data/nyc/giant_polygon.shp by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/giant_polygon.shx by
file...
file:/C:/tomcat/webapps/geoserver/data/data/nyc/giant_polygon.dbf by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/giant_polygon.prj by
2014-02-13 10:50:56,018 DEBUG [org.geotools.data.shapefile] - Read lock:
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poi.shp by
2014-02-13 10:50:56,018 TRACE [org.geotools.data.shapefile] - Shapefile
2014-02-13 10:50:56,018 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poi.shx by
2014-02-13 10:50:56,018 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poi.dbf by
2014-02-13 10:50:56,018 TRACE [org.geotools.data.shapefile] - Dbase File
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poi.prj by
2014-02-13 10:50:56,018 TRACE [org.geotools.data.shapefile] - PRJ reader has
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poly_landmarks.shp by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poly_landmarks.shx by
file...
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poly_landmarks.dbf by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/poly_landmarks.prj by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/tiger_roads.shp by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/tiger_roads.shx by
file...
file:/C:/tomcat/webapps/geoserver/data/data/nyc/tiger_roads.dbf by
file:/C:/tomcat/webapps/geoserver/data/data/nyc/tiger_roads.prj by
2014-02-13 10:50:56,034 DEBUG [org.geotools.data.shapefile] - Read lock:
file:/C:/tomcat/webapps/geoserver/data/data/shapefiles/states.shp by
2014-02-13 10:50:56,034 TRACE [org.geotools.data.shapefile] - Shapefile
2014-02-13 10:50:56,034 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/shapefiles/states.shx by
2014-02-13 10:50:56,034 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/shapefiles/states.dbf by
2014-02-13 10:50:56,034 TRACE [org.geotools.data.shapefile] - Dbase File
file:/C:/tomcat/webapps/geoserver/data/data/shapefiles/states.prj by
2014-02-13 10:50:56,034 TRACE [org.geotools.data.shapefile] - PRJ reader has
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_cities.shp
by org.geotools.data.shapefile.shp.ShapefileReader
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_cities.shx
by org.geotools.data.shapefile.shp.IndexFile
file...
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_cities.dbf
by org.geotools.data.shapefile.dbf.IndexedDbaseFileReader
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_cities.prj
by org.geotools.data.shapefile.prj.PrjFileReader
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_roads.shp by
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_roads.shx by
file...
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_roads.dbf by
2014-02-13 10:50:56,049 DEBUG [org.geotools.data.shapefile] - Read lock:
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_roads.prj by
2014-02-13 10:50:56,049 TRACE [org.geotools.data.shapefile] - PRJ reader has
2014-02-13 10:50:56,049 TRACE [org.geotools.data.shapefile] - Dbase File
2014-02-13 10:50:56,049 TRACE [org.geotools.data.shapefile] - Shapefile
2014-02-13 10:50:56,049 TRACE [org.geotools.data.shapefile] - IndexFile has
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_state_boundaries.shp
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_state_boundaries.shx
2014-02-13 10:50:56,049 TRACE [org.geotools.data.shapefile] - Reading from
file...
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_state_boundaries.dbf
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_state_boundaries.prj
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_water_bodies.shp
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_water_bodies.shx
file...
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_water_bodies.dbf
file:/C:/tomcat/webapps/geoserver/data/data/taz_shapes/tasmania_water_bodies.prj
2014-02-13 10:52:39,836 DEBUG [org.geotools.data.shapefile] - Read lock:
by Shapefile Datastore's getBounds Method
This same geoserver is working in my windows 7 machine.
Can please help me, how can I solve this issue in windows 2008 server(Layer
not able to publish when click *save* button).
Thanks and Regards
Manoharan G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Not-able-to-publish-the-layer-in-Geoserver-tp5097207p5103537.html
GeoServer 2.1.4? Are you sure?
That said, I don't see anything wrong in the log, at least in the
portion mentioned.
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
file...
file...
file...
file...
file...
file...
file...
file...
file...
file...
file...
file...
file...
file...
Thanks and Regards
Manoharan G
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
yes.
This is geoserver 2.1.4
Subversion Revision: 17150
Buid Date: 01 -Jun-2012 17:02
GeoTools version: 2.7.5 (rev 38793)
Thanks and Regards
Manoharan G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Not-able-to-publish-the-layer-in-Geoserver-tp5097207p5103570.html
Ciao Manoharan,
as Jody suggested, I would move the discussion to the users list.
That said, I would test using a newer version of GeoServer, like 2.4.4.
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Thu, Feb 13, 2014 at 12:39 PM, mano3688 <mano3688@anonymised.com> wrote:
yes.
Thanks and Regards
Manoharan G
Hi, I tested with 2.4.4. version also.
I can't able to publish shp file,raster data and postgis layer also.
But I can able to create workspace and store.
Can you help me for fixing this issue an windows 2008 server.
Thanks and Regards,
Manoharan G
View this message in context: http://osgeo-org.1560.x6.nabble.com/Not-able-to-publish-the-layer-in-Geoserver-tp5097207p5103608.html
