so I went ahead and prototyped a bit the idea of using xsd:nil=“true” to mark null
elements, the results given back by GeoServer with the modified feature transformer
validate fine in Eclipse, here is a sample from the “nulls” dataset used for CITE tests:
<wfs:FeatureCollection xmlns=“http://www.opengis.net/wfs”
xmlns:wfs=“http://www.opengis.net/wfs” xmlns:it.geosolutions=“http://www.geo-solutions.it”
xmlns:gml=“http://www.opengis.net/gml” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance”
xsi:schemaLocation=“http://www.opengis.net/wfs http://localhost:8080/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd http://www.geo-solutions.it http://localhost:8080/geoserver/it.geosolutions/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=it.geosolutions%3ANulls”>
gml:boundedBy
gml:nullunknown</gml:null>
</gml:boundedBy>
gml:featureMember
<it.geosolutions:Nulls fid=“Nulls.0”>
it.geosolutions:descriptionnullFeature </it.geosolutions:description>
it.geosolutions:name
</it.geosolutions:name>
it.geosolutions:boundedBy
<gml:Polygon srsName=“http://www.opengis.net/gml/srs/epsg.xml#32615”>
gml:outerBoundaryIs
gml:LinearRing
<gml:coordinates xmlns:gml=“http://www.opengis.net/gml”
decimal=“.” cs=“,” ts=" ">500000,500000 500000,500100 500100,500100
500100,500000 500000,500000</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</it.geosolutions:boundedBy>
<it.geosolutions:integers xsi:nil=“true” />
<it.geosolutions:dates xsi:nil=“true” />
<it.geosolutions:pointProperty xsi:nil=“true” />
</it.geosolutions:Nulls>
</gml:featureMember>
</wfs:FeatureCollection>
However I wanted to have a validation test also in the build and tried something as follows, using
the Parser in validating mode:
- Validates a document against the
- @param dom
- @param configuration
protected void checkValidationErrors(Document dom, Configuration configuration) throws Exception {
Parser p = new Parser(configuration);
p.setValidating( true );
p.parse( new DOMSource( dom ) );
if ( !p.getValidationErrors().isEmpty() ) {
for ( Iterator e = p.getValidationErrors().iterator(); e.hasNext(); ) {
SAXParseException ex = (SAXParseException) e.next();
System.out.println( ex.getLineNumber() + “,” + ex.getColumnNumber() + " -" + ex.toString() );
fail( “Document did not validate.”);
public void testNullValues() throws Exception {
Document doc = getAsDOM(“/wfs?request=GetFeature&typename=” + getLayerId(MockData.NULLS) + “&version=1.0.0&service=wfs”);
print(doc);
checkValidationErrors(doc, (Configuration) applicationContext.getBean(“xmlConfiguration-1.0”));
Unfortunately that breaks when it finds the back reference to DescribeFeatureType cannot be resolved
(because GeoServer is not really running). Do you know if there is any workaround for that?
I thought that maybe I can try to modify the DOM and have the schema location point to a local file
with the schema… seems a bit rough though, any better idea?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 339 8844549
