[Geoserver-devel] nurc:pk50095 doesn't load properly in tomcat
Hey all, I’ve managed to consistently reproduce a problem with the default data in GeoServer in the war download.
Basically if you try to do any WMS GetCapabilities or any GetMap request against pk50095 layer then you get some sort of error about ‘unable to get reader for this coverage layer’. Weirdly I don’t get this problem with any of the binary releases. But I’ve got it with tomcat 6.0.29 on both Mac and a Windows XP VM, against beta3 and a nightly build from the 10th.
Full catalina.out logs are below, starting up and then do a WMS 1.3 request (which failed), a WMS 1.1.1 request (which failed) and a WMS layer preview with jpeg (which failed).
If the layer is removed everything works fine. So I’d say if we can get a fix in for RC1 then great. If not we should probably just remove that layer as a sample layer.
INFO: Deploying web application archive geoserver.war
Jan 12, 2011 11:24:48 AM org.apache.catalina.loader.WebappClassLoader validateJarFile
INFO: validateJarFile(/Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/WEB-INF/lib/servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
12 Jan 11:24:57 WARN [geoserver.logging] - log4jConfigFile ‘DEFAULT_LOGGING.properties’ couldn’t be found in the data dir, so GeoServer will install the various logging config file into the data dir, and then try to find it again.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
12 Jan 11:25:05 ERROR [geoserver.global] -
  • GEOSERVER_DATA_DIR: /Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/data
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘burg’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘capitals’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘cite_lakes’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘dem’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘giant_polygon’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘grass’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘green’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘line’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘poi’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘point’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘poly_landmarks’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘polygon’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘pophatch’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘population’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘rain’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘raster’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘restricted’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘simple_roads’
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style ‘simple_streams’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded style ‘tiger_roads’
12 Jan 11:25:06 WARN [org.geoserver] - No default workspace was found.
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘cite’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘it.geosolutions’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘nurc’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘sde’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘sf’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘tiger’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace ‘topp’
12 Jan 11:25:06 INFO [org.geoserver] - Loaded store ‘arcGridSample’, enabled
12 Jan 11:25:06 INFO [org.geoserver] - Loaded coverage store ‘arcGridSample’
12 Jan 11:25:10 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
12 Jan 11:25:10 INFO [org.geoserver] - Loaded coverage ‘Arc_Sample’, enabled
12 Jan 11:25:10 INFO [org.geoserver] - Loaded coverage ‘arcGridSample’
12 Jan 11:25:10 INFO [org.geoserver] - Loaded layer ‘Arc_Sample’
12 Jan 11:25:10 INFO [org.geoserver] - Loaded store ‘img_sample2’, enabled
12 Jan 11:25:10 INFO [org.geoserver] - Loaded coverage store ‘img_sample2’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage ‘Pk50095’, enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage ‘img_sample2’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded layer ‘Pk50095’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded store ‘mosaic’, enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage store ‘mosaic’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage ‘mosaic’, enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded layer ‘mosaic’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded store ‘worldImageSample’, enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage store ‘worldImageSample’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage ‘Img_Sample’, enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage ‘worldImageSample’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded layer ‘Img_Sample’
12 Jan 11:25:11 INFO [org.geoserver] - Loaded store ‘sf’, enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded data store ‘sf’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘archsites’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘sf’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘archsites’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘bugsites’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘bugsites’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘restricted’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘restricted’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘roads’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘roads’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘streams’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘streams’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store ‘sfdem’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded coverage store ‘sfdem’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded coverage ‘sfdem’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘sfdem’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store ‘nyc’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded data store ‘nyc’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘giant_polygon’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘nyc’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘giant_polygon’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘poi’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘poi’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘poly_landmarks’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘poly_landmarks’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘tiger_roads’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘tiger_roads’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store ‘states_shapefile’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded data store ‘states_shapefile’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘states’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘states_shapefile’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘states’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store ‘taz_shapes’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded data store ‘taz_shapes’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘tasmania_cities’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘taz_shapes’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘tasmania_cities’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘tasmania_roads’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘tasmania_roads’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘tasmania_state_boundaries’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘tasmania_state_boundaries’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type ‘tasmania_water_bodies’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer ‘tasmania_water_bodies’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer group ‘spearfish’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer group ‘tasmania’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer group ‘tiger-ny’
12 Jan 11:25:12 INFO [org.geoserver] - Loaded service ‘wcs’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded service ‘wfs’, enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded service ‘wms’, enabled
12 Jan 11:25:12 INFO [storage.DefaultStorageFinder] - *************************************************************************************************************************************************
12 Jan 11:25:12 INFO [storage.DefaultStorageFinder] - *** Reverting to java.io.tmpdir /Users/cholmes/Downloads/apache-tomcat-6.0.29/temp/geowebcache for storage. Please set GEOWEBCACHE_CACHE_DIR. ***
12 Jan 11:25:13 INFO [jdbc.JDBCMBWrapper] - MetaStore database is version 120
12 Jan 11:25:13 INFO [config.XMLConfiguration] - Failed to find geowebcache.xml. This is not a problem unless you are trying to use a custom XML configuration file.
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding layers from GeoServer Catalog Configuration
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: tiger-ny
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: nurc:Arc_Sample
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: tiger:poly_landmarks
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: spearfish
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: tiger:giant_polygon
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: sf:roads
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: tiger:tiger_roads
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: nurc:Img_Sample
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: sf:archsites
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: sf:restricted
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: sf:sfdem
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: tasmania
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_roads
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_cities
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_water_bodies
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: topp:tasmania_state_boundaries
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: sf:streams
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: nurc:Pk50095
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: nurc:mosaic
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: topp:states
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: sf:bugsites
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding: tiger:poi
12 Jan 11:25:13 ERROR [config.XMLConfiguration] - Configuration file cannot be read or does not exist!
12 Jan 11:25:13 INFO [config.XMLConfiguration] - Found configuration file in /Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/…/resources
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - Adding layers from /Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/…/resources
12 Jan 11:25:13 ERROR [layer.TileLayerDispatcher] - Configuration /Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/…/resources contained no layers.
12 Jan 11:25:13 ERROR [layer.TileLayerDispatcher] - Error reading service information from /Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/…/resources: Error parsing file /Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/…/resources/geowebcache.xml
12 Jan 11:25:13 INFO [layer.TileLayerDispatcher] - ConfigurationLoader completed
12 Jan 11:25:14 INFO [geowebcache.GeoWebCacheDispatcher] - Invoked setServletPrefix(gwc)
12 Jan 11:25:14 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller…
12 Jan 11:25:14 INFO [georss.GeoRSSPoller] - No enabled GeoRSS feeds found, poller will not run.
12 Jan 11:25:14 INFO [rest.RESTDispatcher] - Created RESTDispatcher with 7 paths
12 Jan 11:25:14 INFO [wfs.WFSService] - Configured to forward to http://localhost:8080/geoserver/wfs , timeout is 600000ms regex filter
12 Jan 11:25:14 INFO [wms.WMSService] - Will NOT recombine tiles for non-tiling clients.
12 Jan 11:25:14 INFO [wms.WMSService] - Will proxy requests to backend that are not getmap or getcapabilities.
Jan 12, 2011 11:25:17 AM org.apache.catalina.startup.HostConfig deployDirectory
INFO: Deploying web application directory docs
INFO: Deploying web application directory examples
INFO: Deploying web application directory host-manager
INFO: Deploying web application directory manager
INFO: Deploying web application directory ROOT
INFO: Deploying web application directory target
Jan 12, 2011 11:25:17 AM org.apache.coyote.http11.Http11Protocol start
INFO: Starting Coyote HTTP/1.1 on http-8080
Jan 12, 2011 11:25:18 AM org.apache.jk.common.ChannelSocket init
INFO: JK: ajp13 listening on /0.0.0.0:8009
Jan 12, 2011 11:25:18 AM org.apache.jk.server.JkMain start
INFO: Jk running ID=0 time=0/94 config=null
Jan 12, 2011 11:25:18 AM org.apache.catalina.startup.Catalina start
INFO: Server startup in 33219 ms
12 Jan 11:25:24 INFO [geoserver.wms] -
Request: getServiceInfo
Request: getCapabilities
Namespace = null
UpdateSequence = null
Version = 1.3.0
Request = GetCapabilities
Get = false
RawKvp = {VERSION=1.3.0, SERVICE=wms, REQUEST=GetCapabilities}
BaseUrl = http://localhost:8080/geoserver/
RequestCharset = null
12 Jan 11:25:25 WARN [wms.capabilities] - Map output format text/html does not include mime type in output format names. Will be excluded from capabilities document.
12 Jan 11:25:25 WARN [wms.capabilities] - Map output format application/xml does not include mime type in output format names. Will be excluded from capabilities document.
12 Jan 11:25:25 WARN [gce.imagemosaic] - Unable to set ordering between tiff readers spi
Jan 12, 2011 11:25:25 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Failed to load the GDAL native libs. This is not a problem unless you need to use the GDAL plugins: they won’t be enabled.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
12 Jan 11:25:26 ERROR [gce.image] - No reader avalaible for this source
org.geotools.data.DataSourceException: No reader avalaible for this source
at org.geotools.gce.image.WorldImageReader.getHRInfo(WorldImageReader.java:292)
at org.geotools.gce.image.WorldImageReader.(WorldImageReader.java:262)
at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:344)
at org.geotools.gce.image.WorldImageFormat.getReader(WorldImageFormat.java:55)
at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:972)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleDimensions(Capabilities_1_3_0_Transformer.java:879)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayer(Capabilities_1_3_0_Transformer.java:792)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayerTree(Capabilities_1_3_0_Transformer.java:736)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayers(Capabilities_1_3_0_Transformer.java:613)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleCapability(Capabilities_1_3_0_Transformer.java:400)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.encode(Capabilities_1_3_0_Transformer.java:264)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.geoserver.wms.capabilities.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:65)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:751)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:233)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:23)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:68)
at org.springframework.security.ui.ExceptionTranslationFilter.doFilterHttp(ExceptionTranslationFilter.java:101)
at org.springframework.security.ui.SpringSecurityFilter.doFilter(SpringSecurityFilter.java:53)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:64)
at org.springframework.security.ui.basicauth.BasicProcessingFilter.doFilterHttp(BasicProcessingFilter.java:174)
at org.springframework.security.providers.anonymous.AnonymousProcessingFilter.doFilterHttp(AnonymousProcessingFilter.java:105)
at org.springframework.security.ui.rememberme.RememberMeProcessingFilter.doFilterHttp(RememberMeProcessingFilter.java:116)
at org.springframework.security.wrapper.SecurityContextHolderAwareRequestFilter.doFilterHttp(SecurityContextHolderAwareRequestFilter.java:91)
at org.springframework.security.ui.AbstractProcessingFilter.doFilterHttp(AbstractProcessingFilter.java:278)
at org.springframework.security.ui.logout.LogoutFilter.doFilterHttp(LogoutFilter.java:89)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:192)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:99)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:83)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:394)
at org.springframework.security.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:406)
at org.springframework.security.util.FilterChainProxy.doFilter(FilterChainProxy.java:185)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:39)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:48)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:109)
at org.springframework.security.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:109)
at org.springframework.security.context.HttpSessionContextIntegrationFilter.doFilterHttp(HttpSessionContextIntegrationFilter.java:235)
at org.springframework.security.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:99)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:71)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:183)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489)
at java.lang.Thread.run(Thread.java:637)
12 Jan 11:25:26 WARN [gce.image] - No reader avalaible for this source
at org.geotools.gce.image.WorldImageReader.(WorldImageReader.java:269)
Caused by: org.geotools.data.DataSourceException: No reader avalaible for this source
… 133 more
12 Jan 11:25:26 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: javax.xml.transform.TransformerException: Translator error
at org.geoserver.wms.capabilities.GetCapabilitiesResponse.write(GetCapabilitiesResponse.java:67)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
… 118 more
Caused by: org.geoserver.platform.ServiceException: Error occurred trying to write out metadata for layer: Pk50095
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayerTree(Capabilities_1_3_0_Transformer.java:739)
… 120 more
Caused by: java.lang.RuntimeException: Unable to acquire a reader for this coverage with format: WorldImage
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleDimensions(Capabilities_1_3_0_Transformer.java:887)
… 127 more
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.openlayers’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.text/html’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.atom’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/atom xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.application/xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:18 WARN [geoserver.web] - Unable to find property: ‘format.wms.image/svg xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
12 Jan 11:32:26 INFO [geoserver.wms] -
12 Jan 11:32:27 ERROR [gce.image] - No reader avalaible for this source
at org.geoserver.catalog.impl.CoverageInfoImpl.getGridCoverageReader(CoverageInfoImpl.java:162)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
at $Proxy10.getGridCoverageReader(Unknown Source)
at org.geoserver.wms.MapLayerInfo.getCoverageReader(MapLayerInfo.java:332)
at org.geoserver.wms.GetMap.run(GetMap.java:301)
at org.geoserver.wms.GetMap.run(GetMap.java:110)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:301)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at $Proxy21.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
12 Jan 11:32:27 WARN [gce.image] - No reader avalaible for this source
… 147 more
12 Jan 11:32:27 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Internal error : unable to get reader for this coverage layer org.geoserver.wms.MapLayerInfo@…2625…
at org.geoserver.wms.GetMap.run(GetMap.java:413)
Ciao Chris,
looking at the apache tomcat version, I believe this is the problem:
http://geo-solutions.blogspot.com/2010/05/fix-geotools-and-geoserver-not-able-to.html
Simone.
Ing. Simone Giannecchini
Founder
Via Poggio alle Viti 1187
phone: +39 0584962313
fax: +39 0584962313
mob: +39 333 8128928
http://www.linkedin.com/in/simonegiannecchini
http://twitter.com/simogeo
On Wed, Jan 12, 2011 at 5:39 PM, Chris Holmes <cholmes@anonymised.com> wrote:
Hey all, I've managed to consistently reproduce a problem with the default
against pk50095 layer then you get some sort of error about 'unable to get
reader for this coverage layer'. Weirdly I don't get this problem with any
of the binary releases. But I've got it with tomcat 6.0.29 on both Mac and
If the layer is removed everything works fine. So I'd say if we can get a
as a sample layer.
validateJarFile
INFO:
'DEFAULT_LOGGING.properties' couldn't be found in the data dir, so GeoServer
to find it again.
- GEOSERVER_DATA_DIR:
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'burg'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'capitals'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'cite_lakes'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'dem'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'giant_polygon'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'grass'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'green'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'line'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'poi'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'point'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'poly_landmarks'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'polygon'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'pophatch'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'population'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'rain'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'raster'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'restricted'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'simple_roads'
12 Jan 11:25:05 INFO [org.geoserver] - Loaded style 'simple_streams'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded style 'tiger_roads'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'cite'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'it.geosolutions'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'nurc'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'sde'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'sf'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'tiger'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded workspace 'topp'
12 Jan 11:25:06 INFO [org.geoserver] - Loaded store 'arcGridSample', enabled
12 Jan 11:25:06 INFO [org.geoserver] - Loaded coverage store 'arcGridSample'
respected:
PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]], PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295]], PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST], AXIS["y",
NORTH], AUTHORITY["EPSG","54004"]]
12 Jan 11:25:10 INFO [org.geoserver] - Loaded coverage 'Arc_Sample', enabled
12 Jan 11:25:10 INFO [org.geoserver] - Loaded coverage 'arcGridSample'
12 Jan 11:25:10 INFO [org.geoserver] - Loaded layer 'Arc_Sample'
12 Jan 11:25:10 INFO [org.geoserver] - Loaded store 'img_sample2', enabled
12 Jan 11:25:10 INFO [org.geoserver] - Loaded coverage store 'img_sample2'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage 'Pk50095', enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage 'img_sample2'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded layer 'Pk50095'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded store 'mosaic', enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage store 'mosaic'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage 'mosaic', enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded layer 'mosaic'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded store 'worldImageSample',
enabled
'worldImageSample'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage 'Img_Sample', enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded coverage 'worldImageSample'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded layer 'Img_Sample'
12 Jan 11:25:11 INFO [org.geoserver] - Loaded store 'sf', enabled
12 Jan 11:25:11 INFO [org.geoserver] - Loaded data store 'sf'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'archsites',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'sf'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'archsites'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'bugsites',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'bugsites'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'restricted',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'restricted'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'roads', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'roads'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'streams',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'streams'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store 'sfdem', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded coverage store 'sfdem'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded coverage 'sfdem', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'sfdem'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store 'nyc', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded data store 'nyc'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'giant_polygon',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'nyc'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'giant_polygon'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'poi', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'poi'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'poly_landmarks',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'poly_landmarks'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'tiger_roads',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'tiger_roads'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store 'states_shapefile',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded data store 'states_shapefile'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'states', enabled
'states_shapefile'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'states'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded store 'taz_shapes', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded data store 'taz_shapes'
'tasmania_cities', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'taz_shapes'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'tasmania_cities'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded feature type 'tasmania_roads',
enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'tasmania_roads'
'tasmania_state_boundaries', enabled
'tasmania_water_bodies', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer 'tasmania_water_bodies'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer group 'spearfish'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer group 'tasmania'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded layer group 'tiger-ny'
12 Jan 11:25:12 INFO [org.geoserver] - Loaded service 'wcs', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded service 'wfs', enabled
12 Jan 11:25:12 INFO [org.geoserver] - Loaded service 'wms', enabled
java.io.tmpdir
120
tiger:giant_polygon
topp:tasmania_roads
/Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/../resources
information from
/Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/../resources:
Error parsing file
/Users/cholmes/Downloads/apache-tomcat-6.0.29/webapps/geoserver/../resources/geowebcache.xml
completed
12 Jan 11:25:14 INFO [georss.GeoRSSPoller] - Initializing GeoRSS poller...
paths
non-tiling clients.
deployDirectory
deployDirectory
deployDirectory
deployDirectory
deployDirectory
deployDirectory
Namespace = null
Version = 1.3.0
Get = false
readers spi
loadGDAL
you need to use the GDAL plugins: they won't be
at
at
org.geotools.gce.image.WorldImageReader.<init>(WorldImageReader.java:262)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
org.geotools.gce.image.WorldImageReader.<init>(WorldImageReader.java:269)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
this source
at
at
... 133 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 118 more
at
at
at
at
at
at
at
at
... 120 more
at
at
at
... 127 more
'format.wms.application/vnd.google-earth.kmz xml' for component:
'format.wms.application/vnd.google-earth.kmz' for component:
'format.wms.kmz' for component:
'format.wms.openlayers' for component:
'format.wms.text/html' for component:
'format.wms.atom' for component:
'format.wms.application/atom xml' for component:
'format.wms.application/xml' for component:
'format.wms.image/svg' for component:
'format.wms.image/svg xml' for component:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
this source
at
at
... 147 more
reader for this coverage layer org.geoserver.wms.MapLayerInfo@anonymised.com
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Protect Your Site and Customers from Malware Attacks
Learn about various malware tactics and how to avoid them. Understand
malware threats, the impact they can have on your business, and how you
can protect your company and customers by using code signing.
http://p.sf.net/sfu/oracle-sfdevnl
Geoserver-devel mailing list
Hmmm… So there’s nothing we can do to code around it at the GeoServer or GeoTools level.
How about we just remove that layer from the default data? It seems to be the only one affected. I feel like it’d be good to make a better impression on the latest tomcats than bombing on any WMS Capabilities request, and then having to adjust some obscure settings. Most users will just move on to another product by that time.
On Wed, Jan 12, 2011 at 12:14 PM, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Chris,
Simone.
Founder
fax: +39 0584962313
as a sample layer.
validateJarFile
INFO:
  • jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class:
    to find it again.
respected:
enabled
‘worldImageSample’
enabled
enabled
enabled
enabled
enabled
enabled
enabled
enabled
‘states_shapefile’
enabled
java.io.tmpdir
120
tiger:giant_polygon
topp:tasmania_roads
information from
Error parsing file
completed
paths
non-tiling clients.
deployDirectory
deployDirectory
deployDirectory
deployDirectory
deployDirectory
deployDirectory
Namespace = null
Version = 1.3.0
Get = false
readers spi
loadGDAL
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
this source
at
at
… 133 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
… 118 more
at
at
at
at
at
at
at
at
… 120 more
at
at
at
… 127 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
this source
at
at
… 147 more
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
On Wed, Jan 12, 2011 at 10:56 PM, Chris Holmes <cholmes@anonymised.com> wrote:
Hmmm... So there's nothing we can do to code around it at the GeoServer or
GeoTools level.
the only one affected. I feel like it'd be good to make a better impression
What I'm wondering more is why the WMS 1.3 capabilities transformer tries
to perform data access to start with (getting a reader)
Do we do the same for the WMS 1.1 one?
Ing. Andrea Aime
Technical Lead
fax: +39 0584962313
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
> GeoTools level.
same thing for 1.1.1. It's getting it to ask for the time and elevation
metadata. Would be good to have that as part of resource info instead.
Gabriel Roldan
groldan@anonymised.com
Expert service straight from the developers
On Thu, Jan 13, 2011 at 8:43 AM, Gabriel Roldán <groldan@anonymised.com> wrote:
> GeoTools level.
Indeed. Reader access might mean database connections and whatnot,
it's risky.
If not in the resource, at the very least guard that part and avoid having it
break the caps generation.
Ing. Andrea Aime
Technical Lead
fax: +39 0584962313
I definitely agree that we should protect the capabilities document. Though I think this is not normally an issue because if anyone tries to configure something that doesn’t work then GeoServer doesn’t let you. So the only ones that can get in are when the data directory is misconfigured from the start. Like I wouldn’t be able to add in the faulty pk50095 layer.
So for the immediate term (like RC1) let’s disable pk50095. People can choose to enable it if they want, but then by default we’re not giving bad capabilities documents in tomcat.
On Thu, Jan 13, 2011 at 3:20 AM, Andrea Aime <andrea.aime@anonymised.com> wrote:
GeoTools level.
What I’m wondering more is why the WMS 1.3 capabilities transformer tries
same thing for 1.1.1. It’s getting it to ask for the time and elevation
it’s risky.
Ing. Andrea Aime
Technical Lead
fax: +39 0584962313
On Fri, Jan 14, 2011 at 2:49 PM, Chris Holmes <cholmes@anonymised.com> wrote:
something that doesn't work then GeoServer doesn't let you. So the only
start. Like I wouldn't be able to add in the faulty pk50095 layer.
So for the immediate term (like RC1) let's disable pk50095. People can
choose to enable it if they want, but then by default we're not giving bad
Works for me
Ing. Andrea Aime
Technical Lead
fax: +39 0584962313
