[Geoserver-devel] Obtaining GML of Point Object in PostGIS via WFC
Eli,
Is your geometry column property listed in the geometry_columns table?
dave
This mail sent through IMP: https://webmail.limegroup.com/
If the geometry column is listed, then I imagine the problem might be
the 3d point. Try it with just a 2d point and see if it works. You
also may try modifying the wkb-enabled tag in the postgis datastore, as
there are two different ways of reading the geometry. WKB is faster,
but WKT might work a little better. But if it works with 2d points,
then please submit this as a bug.
Chris
Quoting dblasby@anonymised.com:
Eli,
table?
dave
This SF.Net email is sponsored by: NEC IT Guy Games.
Get your fingers limbered up and give it your best shot. 4 great
events, 4
opportunities to win big! Highest score wins.NEC IT Guy Games. Play
to
win an NEC 61 plasma display. Visit http://www.necitguy.com/?r=20
Geoserver-devel mailing list
