[Geoserver-devel] Odd GeoServerDataDirectory behaviour
While working on the fix to GEOS-8134, I encountered the following:
The GeoServerDataDirectory class has a number of “get__()” methods with a workspace version and a no workspace (global) version.For example: getStyles().
Typically, in the catalog if a null workspace is provided, the global ‘workspace’ is assumed.
However, if you provide a null workspace to one of these methods, you get back the root of the data dir, instead of whatever you were asking for. This behaviour seems contrary to how most of the rest of GeoServer works, and rather error prone.
I would like to suggest changing these methods to handle the case of a null workspace as if it were the global “workspace”.
Torben
Yes, that looks like it may have been a problem introduced when we switched to ResourceStore.
Kevin Michael Smith
[<smithkm@anonymised.com>](mailto:smithkm@anonymised.com)
I cannot see a situation where the current behavior has any benefit and
it seems to me that returning the root directory is dangerous and an
inconsistent behavior.
Imagine the case where we want to remove something but for some
reason the workspace is NULL … we may end up removing the whole
data directory.
As commented on this PR [1] I would expect one of this two behaviors:
  • ignore the workspace if it is NULL
  • throw an exception if the workspace is NULL
[1] https://github.com/geoserver/geoserver/pull/2445
Nuno Oliveira
GeoServer Professional Services from the experts! Visit [http://goo.gl/it488V](http://goo.gl/it488V) for more information.
Nuno Miguel Carvalho Oliveira
@nmcoliveira
Software Engineer
Via di Montramito 3/A
55054  Massarosa (LU)
fax:      +39 0584 1660272
[http://www.geo-solutions.it](http://www.geo-solutions.it)
[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Kevin Michael Smith
Check out the vibrant tech community on one of the world's most
engaging tech sites, Slashdot.org! [http://sdm.link/slashdot](http://sdm.link/slashdot)
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
Since it seems like this is definitely a bug, I’ve reported it as its own issue here: https://osgeo-org.atlassian.net/browse/GEOS-8221
I’ll put together a fix for that one, which will probably supersede the current fix to GEOS-8134.
Torben
On Wed, Jul 12, 2017 at 1:16 AM, Nuno Oliveira <nuno.oliveira@anonymised.com8…> wrote:
data directory.
Kevin Michael Smith
[Geoserver-devel@anonymised.com366...sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
Geoserver-devel@anonymised.com.366…sourceforge.net
+1 thanks Torben.
Torben
On Wed, Jul 12, 2017 at 1:16 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
data directory.
Kevin Michael Smith
[Geoserver-devel@anonymised.comsourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
Nuno Oliveira
@nmcoliveira
Software Engineer
PR here: https://github.com/geoserver/geoserver/pull/2460
I’ve grabbed the test cases from the GEOS-8134 fix, and closed that PR, as it gets fixed by this one.
Torben
On Wed, Jul 12, 2017 at 9:55 AM, Nuno Oliveira <nuno.oliveira@anonymised.com> wrote:
+1 thanks Torben.
Torben
Nuno Oliveira
@nmcoliveira
Software Engineer
On Wed, Jul 12, 2017 at 1:16 AM, Nuno Oliveira <nuno.oliveira@anonymised.comit> wrote:
data directory.
Kevin Michael Smith
[<smithkm@anonymised.com...>](mailto:smithkm@anonymised.com)
[Geoserver-devel@anonymised.comrge.net](mailto:Geoserver-devel@lists.sourceforge.net)
Nuno Oliveira
@nmcoliveira
Software Engineer
