[Geoserver-devel] Official Docker image?
Hello everyone,
I wonder if there’s something close to an official geoserver docker image?
If not, these ones look promising as a starting point <https://hub.docker.com/r/oscarfonts/geoserver> and makes me wonder if Oscar Fonts would be willing to step up as the maintainer. Oscar is a great guy so I’m thinking he will.
In any case, what do you guys think? Worth having official docker images? are there any already?
Gabriel Roldán
Dear Gabriel,
this is an interesting topic, which we discussed a few times here at GeoSolutions.
There are a few good docker images around side from this one from oscar; we have our own, there is one from Kartoza, there is one from Thinkwhere, etc…
All of them or good but each one of them has something good and something bad, infact we ended up doing our own; this does not mean that are own is the best but that our own is the one we like.
Someone else might jump in and say he does not like because of this and/or because of that…
Long story short, I would not select an “official” docker image but we might want to reference the good ones we have around.
Then it is up to the users to decide which is the best one for them, according to their needs and experience.
Happy to hear other opinions.
Simone Giannecchini
Visit http://bit.ly/gs-services for more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
Via di Montramito 3/A
mob: +39 333 8128928
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Simone, thanks for your reply.
I understand your points and they make sense, yet I still feel like it’d be good to have a bare minimum “official” image. By one side we could instruct to try out geoserver by just pulling geoserver/ image, and by the other it would make it easier to justify a choice of docker image when working on a related project like it’s my case now. Of course, I could build my own, but I think there could be a lot of other people in the same situation. My current one being I’m using the docker-maven-plugin to run integration tests against a live instance and customer would be happier if I used some sort of official image.
I agree none would fit all cases. I reckon I’m rather new to this arena and amazed by the possibilities and options it brings out, and thought having a simple barebones per release tagged image submitted to docker hub would be a good idea.
Let’s leave the idea floating around and see what happens.
Gabe.
Gabriel Roldán
I think a bare, minimum “official” image would be a good start for many people. Customers can always use the official version as a base FROM image when building a derived image for their own use.
Chris Snider
Senior Software Engineer
pa-logo-email
(attachments)
Gabe.
El vie., 8 de mar. de 2019 a la(s) 07:33, Simone Giannecchini (simone.giannecchini@…1268…) escribió:
Dear Gabriel,
Simone Giannecchini
@simogeo
Founder/Director
On Thu, Mar 7, 2019 at 11:29 PM Gabriel Roldan <gabriel.roldan@…403…> wrote:
Hello everyone,
Gabriel Roldán
Geoserver-devel mailing list
Gabriel Roldán
