[Geoserver-devel] Offline SLD rendering , filtering and extraction
Hi ,
is it possible to render SLD (like in geoserver )offline, with filtering capabilities like CQL and also to extract them as an image)
what would you suggest
All we have at the moment is Vector data in Spatialite (sqlite)
the use case is to draw SLD styled vector as user draws and then export as image
thanks
Imran Khan
Software Developer
Planview Utility Services Ltd.
Mobile: 647-220-3551
imran.khan@anonymised.com
www.planview.ca
Suite 201
7270 Woodbine Ave
Markham, ON
L3R 4B9
Part of the OEC Family of Companies
Lead • Innovate • Commit To Excellence
GeoServer is built using the GeoTools library which provides data access, rendering, etc… - for more information see https://docs.geotools.org/latest/userguide/ where the tutorials provide the background you need to produce offline rendering.
IMPORTANT
Please note that it is against the GeoServer project’s communication standards to email individuals directly as you have done. In the open source community it is not considered professional to email folks individually. It is not effective at community building (for other individuals that share the same question as you) and the developers are not in a personal position to reply (although this level of service is sometimes available via commercial support).
This is especially sad as you have emailed individuals directly as part of the same thread as mailing lists they are not subscribed to (making it impossible for them to communicate).
aside: Your corporate tacking image (mailtrack) is also not especially useful when emailing mailing lists that are archived and accessed many times.
Jody Garnett
Hello Imran,
Please only mail to mailing address, people already part of mailing list will get the mail anyway :slight_smile:
As for your question
You need to put this question on the Geotools user mailing list. Geotools library is the backbone of Geoserver.
You can certainly acheive this using Geotools, take a look at geotools examples related to Styling and Filtering
http://docs.geotools.org/latest/userguide/tutorial/
regards,
Imran
On Sat, 28 Sep 2019 at 7:33 AM, Imran Khan <imran.khan@anonymised.com> wrote:
Hi ,
thanks
Imran Khan
Software Developer
imran.khan@…5705…
www.planview.ca
Suite 201
7270 Woodbine Ave
Markham, ON
L3R 4B9
Mailtrack
Sender notified by
Mailtrack
19-09-27, 12:36:13 p.m.
This e-mail is confidential and is intended for the above-named recipient(s) only. If you are not the intended recipient, please notify us by telephone or return e-mail immediately and delete this e-mail from your system without making a copy. Any unauthorized use or disclosure of this e-mail is prohibited.
This message is being sent to you by Planview Utility Services Ltd., 7270 Woodbine Avenue, Suite 201, Markham, Ontario. If you no longer wish to receive email communications including information about our company, information about your ongoing use of our products and services or about products and services we are introducing that may be of interest to you, invitations to or information about events you can unsubscribe at any time by contacting us at unsubscribe@anonymised.com
Geoserver-devel mailing list
Sent from Gmail Mobile
