[Geoserver-devel] OGC Filter Timezone issue
Hello,
I’m currently invoking a WFS exposed by geoserver that interrogates a JDBC based layer.
The underlying table has a TIMESTAMP field, and the user interface can call the WFS using a time parameter.
So, if in the invocation we pass something like:
ogc:PropertyIsEqualTo
ogc:PropertyNameMY_TIMESTAMP</ogc:PropertyName>
ogc:Literal2016-04-18T10:00:00Z</ogc:Literal>
</ogc:PropertyIsEqualTo>
I would expect that my db record with MY_TIMESTAMP field set to ‘2016-04-18T10:00:00Z’ is returned, but this is not the case.
But if I pass something like:
ogc:Literal2016-04-18T10:00:00+02:00</ogc:Literal>
the result is returned:
gml:featureMember
<MY_FEATURE fid=“MY_FEATURE.62”>
62
<MY_TIMESTAMP>2016-04-18T10:00:00</MY_TIMESTAMP>
</MY_FEATURE>
</gml:featureMember>
It seems that the server does not care about the timezone of the database field but it considers the default timezone of the OS when evaluating an OGC filter.
This is strange, since the filter is in +02:00 TZ and the returned record is in UTC TZ
Now, I found that when launching the Geoserver in standalone mode, if I add the ‘-Duser.timezone=UTC’ to start parameters the problem disappears.
Another solution is to change the timezone on the hosting OS.
This can be a good solution if Geoserver runs in a dedicated VM or as a standalone process.
But how to deal with machines on which I can’t change the timezone because there are other running services?
And also, how to deal geoserver deployed into an Application Server?
Probably I can’t launch the AS with the ‘-Duser.timezone=UTC’ option since there are other services that exposes functionalities that would be compromised by this setting.
Am I facing a known issue or what? Any suggestion?
Thank you and best regards
Francesco Fornari
Java Tech Expert
ACS S.p.A.
Rome - ITALY
Hi Francesco,
these questions are better asked on the user list, the dev list hosts discussion between
people actually working on the GeoServer own code (instead of using it).
That said, which version of GeoServer are you using? Some fixes regarding timezones
have been done in the last year, but I believe the only landed on 2.8.x and newer.
On Wed, Apr 20, 2016 at 9:49 AM, Francesco Fornari <fra.fornari@…403…> wrote:
Hello,
gml:featureMember
62
</MY_FEATURE>
Francesco Fornari
Java Tech Expert
ACS S.p.A.
Rome - ITALY
Find and fix application performance issues faster with Applications Manager
Applications Manager provides deep performance insights into multiple tiers of
your business applications. It resolves application problems quickly and
reduces your MTTR. Get your free trial!
https://ad.doubleclick.net/ddm/clk/302982198;130105516;z
Geoserver-devel mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
