Hi All,
It seems that the classes which deal with the OGC functions within the SLD are not properly handling situations where there is no label to add.
There may be a record received from the query, but no label within that result. Running performance tests (with about 350,000 samples, I receive hundreds of NPE errors in the GS logs)
2011-03-11 08:24:24,781 ERROR [renderer.label] - Error adding label to the label cache
java.lang.NullPointerException
at org.geotools.filter.function.StaticGeometry.strToUpperCase(StaticGeometry.java:430)
at org.geotools.filter.function.FilterFunction_strToUpperCase.evaluate(FilterFunction_strToUpperCase.java:49)
at org.geotools.filter.expression.ExpressionAbstract.evaluate(ExpressionAbstract.java:63)
at org.geotools.renderer.label.LabelCacheImpl.put(LabelCacheImpl.java:264)
at org.geotools.renderer.lite.StreamingRenderer.processSymbolizers(StreamingRenderer.java:2252)
at org.geotools.renderer.lite.StreamingRenderer.process(StreamingRenderer.java:2158)
at org.geotools.renderer.lite.StreamingRenderer.drawOptimized(StreamingRenderer.java:2061)
at org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:1931)
at org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:766)
Has anyone else come across this?
Steve
On Fri, Mar 11, 2011 at 10:07 AM, Steve Way
<Steve.Way@anonymised.com> wrote:
Hi All,
label cache
at
at
at
at
at
at
at
at
at
Yep, there is also a tentative patch here, but it seems no one has had
the time to review
and apply it so far:
http://jira.codehaus.org/browse/GEOS-4105
Ing. Andrea Aime
Tech lead
Via Poggio alle Viti 1187
fax: +39 0584 962313
mob: +39 333 8128928
http://www.youtube.com/user/GeoSolutionsIT
http://www.linkedin.com/in/andreaaime
http://twitter.com/geowolf
