The OGC has open subscriptions for fundings around geoparquet related dev.
I wonder if it is interesting for GeoServer to have a specific geoparquet datastore or do we rely only on the ogr extension to support it?
In first case, do you plan to ask funds or not? If not, we (camptocamp) are going probably to step up.
Regards
Alexandre
Dear Alexandre,
we, as in GeoSolutions, were planning to request funding to create a plugin to contribute back to GeoServer.
I will discuss tomorrow with Andrea and bring this discussion offline, eventually.
Simone Giannecchini
Ing. Simone Giannecchini
@simogeo
Founder/Director GeoSolutions Italy
President GeoSolutions USA
mob: +39 333 8128928
US: +1 (845) 547-7905
http://www.geosolutionsgroup.com
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
just a quick note for everyone, the call is explicit about avoiding viral licenses,
so the reader/writer work should be done in GeoTools (with possibly light integration
in GeoServer if we want to have it produce GeoParquet as a WFS output, for example).
Simone Giannecchini
@simogeo
Andrea Aime
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 339 8844549
