[Geoserver-devel] OGC Table Join Service (TJS) Extension
We are an environmental engineering company and we have develop a TJS extension for GeoServer (Table Join Service - OGC).
This work was carried out on request of the DREAL Corse and this extension is based on the excellent https://github.com/thijsbrentjens/geoserver/tree/tjs_2.2.x/ (seems not to be maintained).
Our work are available on github :
https://github.com/geohyd/geoserver_tjs_ext
One release for geoserver 2.18 are available with jar :
https://github.com/geohyd/geoserver_tjs_ext/tree/2.18
This project still needs some improvement (show README.md), but it works !
I don’t know if this extension could be added to the other extensions of the geoserver “community”, neither how to propose it.
Best regards,
Jonathan Durand
Antea®Group France
Hey Jonathan:
New community modules are welcome, the idea is to encourage participation, and reduce folks accidentally duplicating work.
Have a look over what is requested here: https://docs.geoserver.org/latest/en/developer/policies/community-modules.html
If you have any questions please ask :slight_smile:
Jody Garnett
Given the history of that module I believe it can be integrated as “found code”, under the specs
of GSIP-186, which allows contribution of community and extensions modules without a CLA.
See the details here.
I have vague memories that the module required core changes too? If that’s the case, I believe those bits
will have to be rewritten from scratch, and contributed with a CLA, while the TJS community module can be contributed
under the GSIP-186 rules (so, two separate PRs, or at least, two separate commits).
Jody, can you confirm my understanding is correct?
Andrea Aime
Visit http://bit.ly/gs-services-us for more information.
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions Group
mob: +39 333 8128928
Your understanding is correct, any chance of finding the original developers with a CLA?
Jody Garnett
For any (original)work by Thijs you can contact him through https://www.brentjensgeoict.nl/achtergrond/
HTH, Mark
