[Geoserver-devel] Old jars and new maven repos
we noticed that on the new maven repos only jars from supported versions are available.
So, GeoTools >= 22 and GeoServer >= 2.16.
Internally we have some builds depending on 21.x and 2.15 stuff, so I was wondering if there is any plan to port those to the new repos or we need to start building those ourselves.
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
You need to start building those yourself, or better yet upgrade to the most recent stable release from that branch (as outlined in the geotools upgrade instructions).
The snapshots are provided in part to collect feedback and contribute to project sustainability. Having snapshots for builds that are no longer active does not assist with this team goal.
That said I am experimenting with a new setting for geotools artifacts that will keep the last couple snapshots for any artifact. Initially the repo was set to remove any snapshots after they went unused for a couple of weeks. The previous boundless repository has been thrown out so the only historical record of prior snapshots may be on your local .m2 repository.
If you find it is mission critical to have snapshots for an archived branch:
  1. The build jobs for the prior branches are still there
  2. Re-enable the job, remove the scheduling so it is just run manually
  3. Update the pom.xml publishing options on the branch, and rerun the build on jenkins, or even run it on your local machine using your own osgeo user id credentials in settings.xml.
On Thu, Apr 23, 2020 at 1:34 AM Mauro Bartolomeoli <mauro.bartolomeoli@anonymised.com> wrote:
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Geoserver-devel mailing list
Hi Jody, thanks for your reply.
We managed to publish on our maven repo from a local PC, updating the poms.
I think it’s enough for now.
Mauro
Mauro Bartolomeoli
@mauro_bart
Technical Lead
Okay, keep in mind that you can deploy to the osgeo repository as well (your osgeo user id can be used in settings.xml for access).
Jody Garnett
