Hi everybody,
I was asked by one of our customers to investigate if https://osgeo-org.atlassian.net/browse/GEOS-6189 is still current and if we can apply the patch that’s attached to the JIRA ticket.
Basically, they are experiencing some issues with single sign out.
I will try to explain what I have understood so far about the proposed patches.
First patch:
In GeoServerCasAuthenticationFilter there is some code to handle single sign out:
if (isLogoutRequest(httpReq)) {
if (singleSignOut) { // do we participate
LOGGER.info(“Single Sign Out received from CAS server → starting log out”);
handler.process(httpReq, httpRes);
LogoutFilterChain logOutChain = (LogoutFilterChain)
getSecurityManager().getSecurityConfig().getFilterChain().getRequestChainByName(“webLogout”);
logOutChain.doLogout(getSecurityManager(), httpReq, httpRes,getName());
} else
LOGGER.info(“Single Sign Out received from CAS server → ignoring”);
return;
The handler.process(…) call is handling the CAS related logout, but it seems that doing that before calling the GeoServer logout chaing is the cause of issues, so we suggest to move the code this way:
} else
return;
This makes sense to me and I did some tests to see if it breaks the logout scenario, with no issues.
Second patch:
Another piece of code is registering the CAS token when available so that it can be used during the single logut procedure.
if (SecurityContextHolder.getContext().getAuthentication()!=null) {
HttpSession session = httpReq.getSession(false);
if (session !=null &&
session.getAttribute(GeoServerCasConstants.CAS_ASSERTION_KEY)!=null && singleSignOut) {
if (LOGGER.isLoggable(Level.INFO))
LOGGER.info("Record HTTP Session “+session.getId()+ " for CAS single sign out”);
The patch proposes to remove this piece of code, but in my opinion this is not correct, since then the single sign out procedure would not be able to find the token when needed.
My idea would be to apply only the first patch, and I will prepare a pull request for that. Is there any CAS expert out there that can give me advices on this?
Thanks
Mauro
Dott. Mauro Bartolomeoli
@mauro_bart
Senior Software Engineer
Via di Montramito 3/A
