[Geoserver-devel] Old orphaned pages in docs
If you goto https://docs.geoserver.org/latest/en/user/community/scripting/ you find a set of 2.19.x pages (rather than 2.21.x that is latest) that are not actually linked to anything (but they are still found in google) - is there any way to delete them? and I guess update the build process to make sure it builds into an empty directory.
Ian
Ian Turton
Yes, we know - we cannot delete pages from S3 (we do not have credentials for that). The best we can do is upload placeholder pages; but we chose not to do so (as we were anticipating having control of geoserver.org domain.
Since that is not happening, I fully support adding placeholder pages to the docs marking content that has graduated, or retired.
Jody Garnett
Ian Turton
Blah it is worse than that, all the doc jobs are broken:
geoserver-2.20.x-livedocs:
Geoserver-main-live-docs:
upload failed: target/main/en/api/1.0.0/coverages.yaml to s3://docs.geoserver.org/main/en/api/1.0.0/coverages.yaml An error occurred (RequestTimeTooSkewed) when calling the PutObject operation: The difference between the request time and the current time is too large.
Looks like it started happening on the 28th…
Once again we do have a new location for docs available at OSGeo, and we can change Jenkins publish location:
It is just I am not volunteering to do so as I have wasted enough time on the domain name transfer.
Jody Garnett
Jody Garnett
Ian Turton
Torben, got a question for you.
Does this error message represent a clock difference between servers? I wonder if recent European timezone change has caused Jenkins to be slightly ahead of itself…
Jody Garnett
Jody Garnett
Jody Garnett
Ian Turton
Yeah, this is a time skew between servers. We ran into this issue somewhat recently (a month or two ago, I think?), and I put a fix in place that ought to have stopped the issue from coming up again (automatic job to refresh the time). Evidently, that didn’t quite work.
DST could have very well caused the issue, I’ll look into it when I next get a chance.
Torben
On Thu, Mar 31, 2022 at 9:21 PM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Mar 30, 2022 at 8:50:05 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Completed 87.3 MiB/96.4 MiB (0 Bytes/s) with 420 file(s) remaining
upload failed: target/2.20.x/en/user/data/vector/properties.html to s3://docs.geoserver.org/2.20.x/en/user/data/vector/properties.html An error occurred (RequestTimeTooSkewed) when calling the PutObject operation: The difference between the request time and the current time is too large.
Jody Garnett
On Mar 30, 2022 at 8:32:45 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
Ian
Ian Turton
Geoserver-devel mailing list
Juan was able to install the correct NTP for the version of ubunutu being used, and ask it to check against the cloud providers servers.
Looks like the documentation build are back.
Jody Garnett
Great, good to hear. Hopefully that keeps things consistent going forward.
Torben
On Fri, Apr 1, 2022 at 6:49 AM Jody Garnett <jody.garnett@anonymised.com> wrote:
Jody Garnett
On Mar 31, 2022 at 10:28:21 PM, Torben Barsballe <torbenbarsballe@anonymised.com> wrote:
Torben
Jody Garnett
Jody Garnett
Jody Garnett
Ian
Ian Turton
