On Fri, Mar 17, 2017 at 5:25 PM, P O'Toole <P.OToole@anonymised.com> wrote:
Feel free to ignore if it's a dumb suggestion, but would it make sense to
configure warnings to be written to the log for when
not-required-but-dangerous-to-omit parameters aren't sent? This might
give developers a hint about what they've done wrong without killing their
chances of getting a response when they're "lucky" enough for Geoserver to
send a response anyway.
It would make a lot of sense for a local developer that's looking at the
logs, someone that owns both the server and the client dev side. That's
common in very small dev shops, but I guess in larger ones the server is
managed by someone else? Still someone might notice the logs.
However, on a production server that would generate a truckload of
warnings... we have a standing request to get exactly the opposite and
don't log at high level errors related to plainly invalid requests, such as
asking for a layer that's not there. Hard to please everybody... (or else,
the amount of configuration required to get the desired control would put
this into a "sponsored feature" realm).
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
