[Geoserver-devel] one row SLD in GeoExt Styler
I started using GeoExt Styler on Geoserver 2.0-RC1, Windows XP. It works fine but I noticed that when I modify a style with Styler, the modified SLD file become 1 row only. This is quite annoying if one wants to modify other parameters or study the file.
Is it possible to come back to a well formatted file? or is it possible to fix this behaviour in the GeoExt Styler plugin?
Thank you very muck
Ale
It's possible to fix it if you can code javascript. Or can fund a developer. But it's just openlayers persistence of its style object in to SLD, so it needs to be taught to do pretty printing of XML. Probably wouldn't take much work, but I'm pretty sure there's not a switch now to print it on multiple lines.
Alessandro Sarretta wrote:
Thank you very muck
Ale
Let Crystal Reports handle the reporting - Free Crystal Reports 2008 30-Day trial. Simplify your report design, integration and deployment - and focus on what you do best, core application coding. Discover what's new with Crystal Reports now. http://p.sf.net/sfu/bobj-july
Geoserver-devel mailing list
Chris Holmes
OpenGeo - http://opengeo.org
