[Geoserver-devel] OneLogin community module
we are starting some work to improve the onelogin community module.
The basic idea is to improve its configurability to transform it into a more generic SAMLv2 SSO module.
First idea: should we rename the module to something like samlv2?
Is there any project rule / concern on renaming existing community modules?
Mauro Bartolomeoli
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Mauro Bartolomeoli
@mauro_bart
Technical Lead
Via di Montramito 3/A
mobile: +39 393 904 1756
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
No rule, community is a play area :slight_smile: if you are the one playing you make the rename.
We only care when it is proposed as an extension.
Jody Garnett
