[Geoserver-devel] OpenGeo and refractions repositories
today Andreas contacted me because he could not build GeoServer
1.6.x. Turned out a needed jar (http://lists.refractions.net/m2/javax/transaction/jta/1.0.1B/)
is not on the main repos and the refractions repo was enabled
only for snapshots. So I added it back.
Yet, when I looked into the trunk pom file, I noticed that
also the snapshot part of RR repo is commented out, and replaced
with opengeo one. That's nice, sort of, in that the opengeo
one is probably faster, but the opengeo one does not contain
all the jars we need.
So I guess before removing RR one completely we should mirror
it at least once? (or alternatively, wipe out the local
repo, try to build, fail, deploy the missing jar, repeat until
done...).
I had the refractions repo commented out locally when I added the restlet
repository to the main pom file. I just fixed that, so if you've been having
trouble building trunk an 'svn up' should help.
-David
On Monday 07 April 2008 09:02:02 Andrea Aime wrote:
done...).
This SF.net email is sponsored by the 2008 JavaOne(SM) Conference
Register now and save $200. Hurry, offer ends at 11:59 p.m.,
Monday, April 7! Use priority code J8TLD2.
http://ad.doubleclick.net/clk;198757673;13503038;p?http://java.sun.com/java
one _______________________________________________
Geoserver-devel mailing list
!DSPAM:4040,47fa1b5e207318362916074!
