So until 2) happens 1) means that using native JAI will end for those who run Geoserver on Windows and that’s because just 32-bit JAI binaries are available for Windows and new JDK builds are all 64-bit, but Linux users are not affected.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett [mailto:jody.garnett@…403…]
Lähetetty: 10. lokakuuta 2018 1:47
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen@…4189…>
Kopio: Geoserver-devel geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] OpenJDK guidance
The answer to that question is two fold …
The same JAI we have now works as far as I know
We are working with LocationTech to get a copy of the JAI codebase (presumably the native code also)
On Tue, Oct 9, 2018 at 2:03 PM Rahkonen Jukka (MML) <jukka.rahkonen@…4189…> wrote:
How about the considerations about native JAI in http://docs.geoserver.org/latest/en/user/production/java.html. Will there be any native JAI for Java 11?
-Jukka Rahkonen-
Lähettäjä: Andrea Aime [mailto:andrea.aime@…1268…]
Lähetetty: 9. lokakuuta 2018 21:24
Vastaanottaja: Torben Barsballe <tbarsballe@…3839…>
Kopio: Geoserver-devel <geoserver-devel@lists.sourceforge.net>
Aihe: Re: [Geoserver-devel] OpenJDK guidanceI’ve been saying that for a while now
On Tue, Oct 9, 2018 at 8:13 PM Torben Barsballe <tbarsballe@…3839…> wrote:
Separate from the licensing perspective, aren’t Oracle JDK and OpenJDK much closer in performance than they were when that documentation was written, to the point that there aren’t substantial differences in performance between the two?
Torben
On Tue, Oct 9, 2018 at 11:02 AM Jody Garnett <jody.garnett@…403…> wrote:
One by product of the changing landscape around Java 11 release - is a license change for the Oracle JDK.
Currently we have the following in our Production Considerations:
GeoServer’s speed depends a lot on the chosen Java Runtime Environment (JRE). The latest versions of GeoServer are tested with both Oracle JRE and OpenJDK. Implementations other than those tested may work correctly, but are generally not recommended.
For best performance we recommend the use Oracle JRE 8 (also known as JRE 1.8).
I think it is time we update our GeoServer release instructions to point towards OpenJDK, and then they can explore other commercial options as they see fit.
Does this require a GSIP or can I propose replacement text here on email?
Background reading:
https://blog.joda.org/2018/09/do-not-fall-into-oracles-java-11-trap.html
https://blog.joda.org/2018/08/java-is-still-available-at-zero-cost.html
Jody Garnett
Geoserver-devel mailing list
https://lists.sourceforge.net/lists/listinfo/geoserver-devel–
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Jody Garnett
