This mail is for asking some opinion about backporting (2.15.x) a StyleInfo Catalog object enhacement (MetadataMap added) described as:
[GEOS-9209] Enhance StyleInfo with MetadataMap on Catalog object and Rest entpoint.
The unique addition is a MetadataMap property on StyleInfo interface and StyleInfoImpl class in the same way it’s implemented on other catalog objects, and naturally added some tests on gs-main and rest-config modules.
PR:
https://github.com/geoserver/geoserver/pull/3489
JIRA issue:
https://osgeo-org.atlassian.net/browse/GEOS-9209
Can I have green light to doing 2.15.x backport for this PR?
Fernando Mino
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Fernando Mino
Software Engineer
Via di Montramito 3/A
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Hi Fernando,
looking at the PR, it seems there is only a single new method to get the metadata map, and support
for it in the implementation bean. No other changes around, so for the moment it’s acting as storage for REST clients
that are aware of the change.
Support for metadata maps serialization is baked into the XStreamPersister for both XML configuration and
REST API, so it should be all transparent, but nevertheless there are changes covering it.
I’m not worried about a backport, but I’d avoid doing it in one month as the backport rule for new functionality,
as it would be close to the 2.15.2 release. Rather have some buffer, so suggest to backport sooner, or given
how trivial the change is, even “now” (where now means, first merge, make sure nothing breaks, and then backport).
Regards, Andrea Aime == GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Thanks Andrea.
Good to know and as you suggest I’ll backport and test it as soon master PR merges successfully.
Fernando Mino
