With Mapserver it has been possible not to name the rootlayer by using a workaround of using an empty name for the MAP. Rootlayer will then have only a title but no name. Nowadays it is configurable in an easier way https://github.com/mapserver/mapserver/issues/5404.
Myself I have never used named rootlayer in our services and we haven’t received any complaints from our users because of that.
-Jukka Rahkonen-
Lähettäjä: Jody Garnett <jody.garnett@…403…>
Lähetetty: keskiviikko 29. toukokuuta 2019 12.36
Vastaanottaja: Jonathan Moules <jonathan-lists@…4460…>
Kopio: GeoServer geoserver-devel@lists.sourceforge.net
Aihe: Re: [Geoserver-devel] Optional flag to remove root Layer in WMS Capabilities documents
That is really neat! Thanks for the background, when do we get a foss4g presentation on your database?
Based on the research do we want to have the option remove root in all cases?
root → groups → layers
group → layers
layer
I assume you are filling what was formally the root SRS list in the “top-level” layer definition in each case?
Jody Garnett
On Tue, 28 May 2019 at 17:08, Jonathan Moules <jonathan-lists@…4460…> wrote:
I believe most WMS clients can already handle no-root-layers, at least if they interact successfully with ArcGIS Server WMS’, which don’t always provide one. For instance try the getcap for:
https://www.geoseer.net/rl.php?ql=1c9ad6b795c81a3a
or
https://www.geoseer.net/rl.php?ql=20e92da97bb6ff7b
This seems to only be true of the /ImageServer/ endpoints. ArcGIS /MapServer/ endpoints have a root layer.
Thredds, QGIS Server and MapServer also have a root layer.
{Jody} … it is just very unusual to see a WMS service configured this way (with a single layer).
From a purely statistical perspective, most WMS services only have have a single layer. Of 116,762 public WMS services in my database, 62,442 have exactly one (1) named layer. Just 54,320 have > 1 layer. That’s across all types of WMS Server.
Note that I only keep “named layers” (layers that have a “name” set and can thus be requested via GetMap), and I don’t keep nested-layers relationships.
Jonathan
On 2019-05-21 08:32, Andrea Aime wrote:
On Tue, May 21, 2019 at 9:27 AM Mauro Bartolomeoli <mauro.bartolomeoli@…1268…> wrote:
Hi Jody. The most interesting use case is when you are asking for a layer group and you get the group as root and the subgroups and layers as child nodes (so not really a single layer, but a tree with a single root, that is not the GS default root, but the group itself).
I would not make it active by default, because I suspect many GeoServer aware WMS clients could stop working.
Yeah, I agree with the idea in general, but best to have it off by default, don’t think I’ve seen a WMS with a single root layer so far. The layer group case should work instead, after all, it’s still a tree, but even in that case, some clients
would break on upgrade if we move from root->group->layers to just group->layers
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information. == Ing. Andrea Aime @geowolf Technical Lead GeoSolutions S.A.S. Via di Montramito 3/A 55054 Massarosa (LU) phone: +39 0584 962313 fax: +39 0584 1660272 mob: +39 339 8844549 http://www.geo-solutions.it http://twitter.com/geosolutions_it ------------------------------------------------------- Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia. This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
Geoserver-devel mailing list
[Geoserver-devel@lists.sourceforge.net](mailto:Geoserver-devel@lists.sourceforge.net)
[https://lists.sourceforge.net/lists/listinfo/geoserver-devel](https://lists.sourceforge.net/lists/listinfo/geoserver-devel)
