Gday Geoserver folks..
I'm having a play with geoserver talking to an Oracle Spatial 9i database..
would like to ask a question about the Oracle datastore..
submitting the following query:
<?xml version="1.0"?>
<wfs:GetFeature service="WFS" version="1.0.0"
outputFormat="GML2"
xmlns:topp="http://www.openplans.org/topp"
xmlns:wfs="http://www.opengis.net/wfs"
xmlns:ogc="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"
<wfs:Query typeName="topp:AIR_PHOTO_INDEX">
<ogc:Filter>
<ogc:Intersects>
<ogc:PropertyName>GEOMETRY</ogc:PropertyName>
<gml:Polygon>
<gml:outerBoundaryIs>
<gml:LinearRing>
<gml:coordinates decimal="." cs=","
ts="">130.84310775,-12.38133377 130.84337329,-12.38129283
130.84344202,-12.38166684 130.84338598,-12.38167355 130.8431756,-12.38169938
130.8431584,-12.3816064 130.84310775,-12.38133377</gml:coordinates>
</gml:LinearRing>
</gml:outerBoundaryIs>
</gml:Polygon>
</ogc:Intersects>
</ogc:Filter>
</wfs:Query>
</wfs:GetFeature>
results in the following SQL being executed on oracle (according to the
catalinga log):
SELECT UFI, PHOTO_ID, PROJECT, RUN, SCALE, CAPTURE_DATE, GEOMETRY FROM
AIR_PHOTO_INDEX WHERE NOT
SDO_RELATE("GEOMETRY",MDSYS.SDO_GEOMETRY(2003,8311,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY(130.84310775,-12.3816064,130.84310775,-12.38133377,130.8431584,-12.38133377,130.8431584,-12.3816064,130.84310775,-12.3816064)),'mask=disjoint
querytype=WINDOW') = 'TRUE'
that query takes about 20 seconds to run on the oracle machine.. and about 30
seconds to return from a geoserver point of view.
However, the query is strange, its asking for all the features NOT NOT in the
specified area.. the following takes about 0.01 seconds, same results returned..
SDO_RELATE("GEOMETRY",MDSYS.SDO_GEOMETRY(2003,8311,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,1),MDSYS.SDO_ORDINATE_ARRAY(130.84310775,-12.3816064,130.84310775,-12.38133377,130.8431584,-12.38133377,130.8431584,-12.3816064,130.84310775,-12.3816064)),'mask=anyinteract
(note i've removed a NOT and subs. disjoint with anyinteract)
.. also the BBOX filter type (i.e. a different WFS query) does not use a
SDO_FILTER like it possibly could, instead a SDO_RELATE the same as above is
generated which are a lot slower.
This problem is greatly amplified on some of our larger datasets such as roads
and cadastre.
What is the status of development on the Oracle datastore ? We would like to use
WFS rather than develop our own SOAP stuff based on more efficient SQL queries..
what are our options in terms of promoting the Oracle datastore development ?
versions: Geoserver is 1.2.4, OS is linux redhat 9, Oracle 9i DB is on Linux
(separate machine)
Thanks in advance..
-ivan
Ivan Price
Spatial Systems Manager
Northern Territory Land Information System
Department of Infrastructure, Planning and Environment
Northern Territory Government
Tel: (08) 8924 4024
Fax: (08) 8924 4045
Email: ivan.price@anonymised.com
