Hello,
I’m interesting in having a look at the source code for the oracle datastore extension for geoserver. I couldn’t locate it in the source for geoserver that I pulled from the subversion repository – could someone point me in the direction of this code? Thanks very much…
Aaron
Aaron_Gundel@anonymised.com wrote:
Hello,
I'm interesting in having a look at the source code for the oracle datastore extension for geoserver. I couldn't locate it in the source for geoserver that I pulled from the subversion repository -- could someone point me in the direction of this code? Thanks very much...
Aaron
Depending on what version of GeoServer you are using, but the development is currently being done in the jdbc-ng module in GeoTools
https://svn.osgeo.org/geotools/branches/2.5.x/modules/unsupported/jdbc-ng/
-Arne
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
Hello,
Aaron
And if you are using the older Oracle datastore, the source is there:
https://svn.osgeo.org/geotools/branches/2.5.x/modules/unsupported/oracle-spatial/
Anyways, the ng is the horse to bet on, the old one will be replaced by it.
DataStores live in GeoTools (they are detected at runtime by GeoServer using SPI). The old OracleDataStore can be found under modules/unsupported/oracle-spatial. For example:
http://svn.osgeo.org/geotools/trunk/modules/unsupported/oracle-spatial/
There is also the jdbc-ng version mentioned by Arne.
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer, CSIRO Exploration and Mining
Australian Resources Research Centre
26 Dick Perry Ave, Kensington WA 6151, Australia
