Has anybody any simple, step by step instructions on how to get the oracle datastore to work.
I keep getting a SEVERE log message saying FeatureTypeInfo bfora:::LOCATIONS ignored - as DataStore bfora is unavailable:org.geotools.data.SchemaNotFoundException: Feature type could not be found for LOCATIONS.
How do i tell geoserver which table to look at and what the columns are (assuming it cannot look this up from the database)
I am getting a connection made to the database.
what is the schema parameter to the oracle datastore - is it the database schema name?
Company Reg No: 4209395 Registered Office: 2 Temple Back East, Temple Quay, BRISTOL. BS1 6EG.
*** This E-mail contains confidential information for the addressee only. If you are not the intended recipient, please notify us immediately. You should not use, disclose, distribute or copy this communication if received in error. No binding contract will result from this e-mail until such time as a written document is signed on behalf of the company. BlueFinger Limited cannot accept responsibility for the completeness or accuracy of this message as it has been transmitted over public networks.***
oracle
datastore to work.
The general GeoServer documentation combined with http://geoserver.sourceforge.net/documentation/user/advanced.htm#oracle
should have enough answers. Let me know what more information should
be put in there. Or we could make a full page of simple oracle
instructions... Sean is the oracle maintainer, so he may be able to
provide better answers.
bfora:::LOCATIONS
could
are
The table to look up should be the <name> element in the featureType's
info.xml file, and it should refer to the oracel datastore. The schema
stuff has been the source of a few problems, you may try just leaving
it out all together - but yes, I think it is the database schema name,
but it's only really necessary if you have two tables of the same name
in different schemas.
hope this helps,
Chris
database
schema name?
Quay,
BRISTOL. BS1 6EG.
only. If
should
in
time as a
Limited
This mail sent through IMP: http://horde.org/imp/
Chris I spent a half hour with Pati (she was testing for us yesterday) not getting oracle to work. I am thinking of *not* including the oracle datastore in the war file.
We can then modify the instructions for the use of oracle to be the inclusion of three jars not two.
